allignment after axle replacement ?
Old May 30, 2006 | 09:38 PM
ukraini9mofo's Avatar
I was wondering will my allignment be off after i get my axles replaced, or does this procedure not phase the allignment of front wheels
Old May 30, 2006 | 09:42 PM
NmexMAX's Avatar
dot dot dot ...
I always get one after I do axles.
Old May 31, 2006 | 02:04 AM
99se5speed's Avatar
SHIFT_up
both of mine were taken off during a clutch job and i didn't get an alignment after, my mechanic even told me not to.
Old May 31, 2006 | 05:09 AM
Conrad283's Avatar
I need a truck
I would get one. Once I replace my axles, I plan to get one.
Old May 31, 2006 | 06:02 AM
NmexMAX's Avatar
dot dot dot ...
Never believe and always question what any mechanic tells you.
Old May 31, 2006 | 06:21 AM
cardana24's Avatar
Blown
my alignment was way off after I changed and axle on my 98. I have D2's on the car, not sure if that makes a difference, but my car was unsafe after I changed the axle.
Old May 31, 2006 | 09:06 AM
nismology's Avatar
I've done axles many times and the alignment was unaffected. The toe doesn't change since the effective length of the tie-rod is the same before and after, the camber changes a negligible amount (maybe a few hundredths of a degree), and the caster isn't adjustable. Save your money.
Old May 31, 2006 | 10:16 AM
cardana24's Avatar
Blown
I am guessing the reason mine was affected so much was because I took out my camber bolts. I am thinking you guys are changing axles with out taking the camber bolts out.
Old May 31, 2006 | 02:04 PM
99se5speed's Avatar
SHIFT_up
I felt no difference in the alignment what so ever.
Old May 31, 2006 | 02:52 PM
MDeezy's Avatar
I fortunately have a lifetime alignment so I'd get one anyway. If anyone who have a lifetime alignment and is going to change their axle soon, should get the print out from their alignment and that should be a good piece of evidence as to wheather or not its needed.
Although it is true, toe isnt affected after an axle change (assuming you didnt disconect the outter tie rod from the spindle)
Amen to that. I havent learned that lesson first hand but have ready countless threads where people listened to foolish info from their "mechanic"
Old May 31, 2006 | 03:32 PM
nismology's Avatar
Originally Posted by MDeezy
IAlthough it is true, toe isnt affected after an axle change (assuming you didnt disconect the outter tie rod from the spindle)
My method involves removing the tie-rod end from the spindle. As long as the locknut on the tie-rod is tightened the effective length of the tie-rod is the same before and after the axle is installed.
It's like changing mobil 1 synthetic oil at 3k. Waste of $$$ IMO...
Old May 31, 2006 | 06:36 PM
oldngivout's Avatar
Willing to learn
When I began working on Nissans, the first few axles I replaced I would disconnect the tie rod. Found it to be completely unnecessary.
If the axles are replaced, or the struts replaced while retaining the stock springs, an alignment would not be needed. Only if there was a problem before the other work was done would there be a need for a front end alignment.
The reason is simple: there is absolutely no provision to change the caster/camber on a factory strut. The only adjustment is the toe, which will be unaffected by either of the two repairs.
Old May 31, 2006 | 07:41 PM
ManualMaxima's Avatar
5th Gen till she dies!
well anytime you mess with suspension you are suppose to get an alignment.......
Old May 31, 2006 | 09:06 PM
nismology's Avatar
Did you not read anything in this thread? I gave specific reasons why the alignment isn't necessary. Your statement is invalid at this point unless there's some facts to go along with it.
Old May 31, 2006 | 09:16 PM
nismology's Avatar
Old Jun 11, 2006 | 07:18 PM
david5611's Avatar
my car just was stolen and crashed the other day and i need a new front axle...how much did you guys pay and did you do the work yourselves?
Old Jun 11, 2006 | 07:42 PM
MDeezy's Avatar
sorry to hear that but glad you got your car back.
~$140 shipped from raxles.com did the work myself in the garage, took about 30 mins.
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
PH98I30
Aug 20, 2015 04:25 PM
classymax420
Aug 6, 2015 06:35 PM
