EGR valve replacement
Old May 31, 2006 | 11:01 AM
95jr6708's Avatar
I have looked at the charts for "troubleshooting egr" which helps very much. My main concern is how to get to where i am going. I am basically looking for a writeup on how to replace the valve. Has anyone replaced the egr valve? if so, i know it is going to be a b*tch but is there anything i should remove to make it a little bit easier, like the throttle body. and what would you recommend to clean carbon buildup?
thanks
Old May 31, 2006 | 08:05 PM
Sounbwoy's Avatar
Didn't you ask about this before?
Look here. Read everything. I even have pictures.
http://forums.maxima.org/showthread.php?t=470051
Old May 31, 2006 | 10:07 PM
95jr6708's Avatar
I did ask about symptoms and stuff but when i got under the hood i found that i needed more help. thanks for the writeup and pictures, it is very much appreciated.
Old Jun 1, 2006 | 07:35 PM
Sounbwoy's Avatar
Let us know how you made out.
Old Jun 1, 2006 | 07:39 PM
speed racer's Avatar
YOur going to have to remove anything that would help you get to the EGR Valve. For example the intake, possible throttle body, vacuum hoses, and miscenllaneous hoses. You want to use either throttle body cleaner or brake cleaner to remove carbon buildup.
Old Jul 1, 2006 | 05:57 PM
cgilley's Avatar
Now it's my turn....
Okay, I read through the thread completely, went down and bought a set of visegrips (*great* suggestion), and I had the EGR valve out. Cleaned it up and every pipe/hose I could find, and now it's time to re-assemble.
Apparently, the EGR pipe requires PERFECT alignment for the nut to go on (this is the big nut). How the heck do I line it back up so I can get the nut to thread back on?
Rationalizing my work on this car as therapy....
Old Jul 1, 2006 | 06:39 PM
Sounbwoy's Avatar
I put the big nut on first, before doing the top one. I was able to get it in three tries.
Old Jul 1, 2006 | 06:49 PM
cgilley's Avatar
doh!
Of course - first thing I will try in the morning... Should be able to wiggle it around with the EGR loose.
Old Jul 2, 2006 | 10:37 AM
cgilley's Avatar
Sounbwoy,
I owe you one. Next time I'm in Raleigh (grew up there), I'll buy you lunch. Loosening the EGR made the connection process so much easier. So, for the moment, no check engine light and car seems to run fine.
chg
Old Jul 2, 2006 | 11:18 AM
95jr6708's Avatar
got around to it.
Well i replaced it...the pipe nut was a huge b*tch to get off the hose...literally had my body standing on the wrench an djumping up and down to get it off..finally gave...minus that it was pretty easy with just the intake assembly off...but the check engine light came on anyway so a waste of time money and sweat...at least i learned something i guess...good luck to the rest of you.
Old Jul 3, 2006 | 06:15 AM
Sounbwoy's Avatar
Sounbwoy,
chg
Glad it worked!
Sounbwoy's Avatar
So the pipe was not clogged??
Old Jul 3, 2006 | 08:02 AM
maxgp1029's Avatar
00vi Equipped.......
97 max se 5 spd.......no EGR
Old Jul 3, 2006 | 01:34 PM
NevadaJack_9's Avatar
EGR Problem
Hey guys my 96 Max threw code P0400 which is the EGR Flow Malfunction. I just need a write up on how to correct this problem. I'm not sure if there is a complete write up around, but your help will be a huge help.
Old Jul 3, 2006 | 01:42 PM
95jr6708's Avatar
Look Closer
Hey man, read the second post on this thread, that sight will tel you EVERYTHING ABOUT EVERYTHING YOU NEED TO KNOW about this and other codes of the same relation...good luck.
Old Jul 4, 2006 | 12:25 PM
drumadore's Avatar
New EGR threw code
I bought my 99 SE at about 73k miles, and soon the engine light came on. The shop I took it to read it as EGR trouble (burning too much gas) and offered to clean it rather than replace it. After it was cleaned, the light was off for about a month and came back on. I was moving out of state and had the car tuned up, tires replaced etc. and the EGR valve replaced. Sure enough, about 2 months after the move the light came back on - but I couldn't exactly take it back to the shop! This was around Feb 05. Until recently, the car has been running fine but with milage around 20mpg.
Now it is chugging all over town and I just found this forum. I've been SOOO broke, but I don't know what to do save take it to a dealership and explain my story - I've paid close attention to the symptoms & contexts. But maybe someone here can help. I've been reading about MAFs and O2 sensors...
What in the world is causing the problem??
iflexsteel
Sep 15, 2015 03:37 AM
lowpost99
22
Sep 2, 2015 04:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
