Radiator support rust out
Old Jun 1, 2006 | 03:11 PM
69CHARGER_RT's Avatar
Any one else have this potentionally dangerous condition?
On my '96 GLE, the front lower radiator support where the center engine cradle bolts to is completely rusted through.
Almost to the point where if the rust holes get any bigger I feel the engine might be able to literally fall out of the car.
Anyone hear any others complaining of this?
Might want to go out & check your car.......
Old Jun 1, 2006 | 03:12 PM
f550maranello2's Avatar
yea im begining to worry abou it a little to man.. it doent look good..
Old Jun 1, 2006 | 03:36 PM
HM_Motorsports's Avatar
There's some posts about this elsewhere. The best option in my opinion is to weld (or have someone that has the capability and ability to weld) a new section in, beefer than stock. And cut the old rust out of course and make sure it's not just going to spread underneath the repair. Mine wasn't bad so I ground out the rust, drilled some drain holes to keep the water from standing above it anymore and covered it with POR-15, restoration shops use it in their projects, great product, very durable, keeps the rust away like no other, but not the cheapest, but should be available at any body supply shop.
Old Jun 1, 2006 | 03:37 PM
Sounds like a plan but I think mine is too far gone for POR-15.
Looks like this could be an expensive repair.
Google search doesnt turn up much on the subject.....
Old Jun 1, 2006 | 04:02 PM
If it's too far gone, then you could have the radiator suport replaced or if you cut some of the rusted part out replace it with some stock steel, use the POR 15 or at least some form of rust protection that's better than factory paint to prevent it from happening again. I realize that's not exactly an easy task as most do not own a welder or any other equipment to do metal work, but it's cheaper than having a shop do it, there's not really an easy way out of it,,,
cant you just buy a new one?
Old Jun 1, 2006 | 04:03 PM
Dont know.....can you?
Old Jun 2, 2006 | 02:50 AM
Bump for the AM crew.....
Old Jun 2, 2006 | 03:28 AM
nhaven's Avatar
here is an old thread
http://forums.maxima.org/showthread....ybrid&t=356046
Old Jun 2, 2006 | 06:13 AM
maximaSE327's Avatar
just go to a junk yard and see if u can find one in better condition... i have the same problema dn i need to replace mine also
Old Jun 2, 2006 | 09:14 AM
yea i guess you can get a new one... ill look for one and let ya guys know...
Old Jun 2, 2006 | 09:17 AM
check out this page everybody.. its #5 right?
http://www.trademotion.com/partlocat...=5&catalogid=2
Old Jun 2, 2006 | 01:05 PM
Originally Posted by nhaven
Thanks for that. Mine looks like the first set of rust pics.....that second one looks downright scary!
I filed a complaint with the NHTSB to see if Nissan will do anything about this.....
Old Jun 2, 2006 | 01:06 PM
That looks right to me....I wonder if thats a bolt in piece or needs to be welded......
Old Jun 9, 2006 | 10:59 AM
buntypatel's Avatar
i installed a new one.. took 1 hour.
Old Jun 9, 2006 | 06:41 PM
Details please.......
You installed a new full radiator support and it only took you one hour?
Is the support bolted in or welded in?
Or did you cut out the lower section & weld in a new piece.....
Old Jun 10, 2006 | 07:12 AM
pmohr's Avatar
No more Maximas...
The radiator support is welded onto the frame, to safely remove it and install a new one, you would need a frame alignment rack (or at least so I've read several times around on here). But it is welded on, I searched around for a bit back when I had my accident in the max, since mine is bent behind the passenger side headlight.
Old Jun 10, 2006 | 04:02 PM
Jatan's Avatar
Same problem with mine - went for an alignment and the guy pointed it out to me
http://www.jatan.net/DSCN0687.JPG (blurry)
http://www.jatan.net/DSCN0688.JPG
http://www.jatan.net/DSCN0689.JPG
http://www.jatan.net/DSCN0690.JPG
Old Jun 11, 2006 | 03:00 AM
Crikies! Now to me, it looks like your's totally seperated from the rad support and the engine didnt fall out.....
Have you repaired your's yet or you still driving like that?
Old Jun 11, 2006 | 07:27 AM
Jatan's Avatar
Wed/Thurs I did the rear injectors and cleaned out the EGR. Then I jacked up the car a little when I was getting the air out of the cooling system - everything was fine then
Friday I drove it to work and then Sat afternoon I went for an alignment and the guy told me about it (so it broke off Fri or Sat). I'm not driving the car right now - its sitting outside with the center beam jacked up a little (hopefully, if no one stole my jack...)
Old Feb 17, 2016 | 07:14 AM
LukeW's Avatar
Did Nissan reply?
I know this is a really old thread, but did Nissan reply?
Thanks!
Old Feb 17, 2016 | 01:05 PM
JvG's Avatar
JvG
Since this thread is ten years old, I doubt anyone from 2006 will reply.
Old Feb 17, 2016 | 08:07 PM
max ride 41's Avatar
ahem, nissan never did squat which left the majority of the op replacing the lower if not the whole rad support ourselves.
Old Feb 17, 2016 | 09:41 PM
BronxSleeperMax187's Avatar
Here A reply Lol.... it cost like $65 brand new. Do it right the first time.
Old Feb 18, 2016 | 05:25 AM
oem is a bit more expensive but it is the only way to go. if you would've searched, you would've found a few threads on this subject already.
Old Feb 18, 2016 | 09:58 PM
MadManMax-M3's Avatar
I concur, go OEM, don't make the mistake I made and go aftermarket and then still have to go in there another time!
Go OEM (less headache and better IMO) or reinforce an aftermarket support with steel one time!
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
