Testing Ignition Coils
Old Jun 1, 2006 | 06:00 PM
marc98se5's Avatar
Is there any way to test the Ignition Coils to see if they are working properly? Here's the issue, I am getting engine knock when climbing a hill or accelerating hard on the highway (sometimes). I was told that this is either the Octane gas I am using, which I usually use 91 but have been using occasionally 89, or it is the Ignition Coils. Before I spend 500 bucks for coils, I wanted to make sure that is the problem. To start off I have been putting 91 Octane and I am on my second tank but I wanted to ask this question if there was anyway to test the coils, maybe with a voltage meter or something? Thanks.
Old Jun 1, 2006 | 06:17 PM
MaximaSE96's Avatar
Maxima Owner
start car...mental note idle...shut-off car unplug a coil....start car...note any change in idle...repeat lather rinse for all six....the one that doesnt change ur idle when unplugged is bad...but it just sounds like fuel starvation how much gas how steep of hill....
Old Jun 1, 2006 | 06:19 PM
MIXXMAX's Avatar
How long were you using 89 Octane? That could be the cause of the knocking noise since our Max's require high Octane 90 and above. As far as the coils, you can hook up a DMM to it and check the resistance of each pin to see if they all compare to be the same within each other.
Old Jun 1, 2006 | 06:22 PM
marc98se5's Avatar
Thanks for the info..As for your above question, WOT and the hill maybe 30 to 40 degree grade (I'm guessing here).
Old Jun 1, 2006 | 06:24 PM
marc98se5's Avatar
Maybe 2 tanks of 89, then I would put 91 and so on.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
zmcneely13
Sep 26, 2015 02:26 PM
