Need Quick Help to anyone with a couple of minutes and a clue
Old Jun 2, 2006 | 04:40 PM
Hitmanforprez's Avatar
2 Things
1) Trying to Reset my ECU using the little screw on the ECU itself. I have done it before, but when I tried today the screw does not stop anymore, now it will turn forever. It used to stop after a few turns either way.
2) When my manual Maxima is just sitting off or at idle and I move the gear shift around it is very loud and if I had to guess I would suggest a hollow sound. Is there an easy way to check the fluid level or top it up? Any other ideas why it sounds like ***? It drives and shifts fine...
Thank you very much to anyone who can help me out
Old Jun 2, 2006 | 04:43 PM
JwaxMax99's Avatar
That screw is delicate, you broke it.
Need a OBDII tool now.
Old Jun 2, 2006 | 04:46 PM
Fack seriously? I was worried about that, will disconnecting the battery reset the ECU also?
Old Jun 2, 2006 | 04:51 PM
RA030726's Avatar
I'm nutty for Nissans
No it wont reset the ECU by unhooking the batt.
Are you saying the car makes a noise when you push the shifter (one way or the other) when running? Thats probably the shift fork touching the syncros sending vibrations down the shift linkage which you hear. Mine makes a noise if I push on it slightly.
Old Jun 2, 2006 | 04:57 PM
Is there any way for me to reset the ECU then? (other than an OBDII tool)
When the car is at Idle or off and I press the clutch and rock the shifter left and right or go through the gears it sounds almost hollow, and it seems loud to me, just wondering if the other standards sound like that.
Old Jun 2, 2006 | 07:40 PM
f550maranello2's Avatar
yea go to autozone and ask them nicely because they arent supposed to reset the light anymore...
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
