AC blowing hot air
Old Jun 3, 2006 | 11:24 AM
Dexter's Avatar
AC blowing hot air
Hey guys, my AC isn't blowing any cold air, I was wondering does the AC system depend on Freyon gas (if so can i DIY a refill) or on coolant?
Another thing does the TB throw any codes when it needs cleaning? How do I know if it needs to be cleaned?
How can I tell if my radiator pump is going bad?
Old Jun 3, 2006 | 12:01 PM
99se5speed's Avatar
SHIFT_up
You can refill it yourself. Any parts store should have the can. You need it to say 134. The TB doesn't throw codes. I just took some carb cleaner and sprayed the butterfly and the outter part of the TB cleaned it off with a white rag and that was that. I have no idea about the pump.
Old Jun 3, 2006 | 01:51 PM
Dexter's Avatar
any instructions available as to how to refill the AC?
Old Jun 3, 2006 | 03:19 PM
Chickan's Avatar
the instructions are on the bottle, it is really pretty straight forward. There is also a thing in the stickies as well. Basically, put your windows down, turn the AC on full and coolest possible, and get a temperature gauge. Attach the refil can to the LOW PRESSURE SIDE! It won't attach to the High Pressure Side, but just make sure you don't. Also, get a kit without a pressure gauge on it, as they are not even close to accurate. Slowly start refilling the system, and when the AC temp starts levelling out (~40* below ambient), then it is full enough. During a 75* day I filled mine until it hit 40*F, and it has been great for over a year now.
And by radiator pump do you mean water pump?
And just clean the TB every 6-12 months.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
