factory alarm going off on its own
Old Jun 4, 2006 | 04:05 AM
blkhawk500's Avatar
Recently I noticed that the factory alarm has been going off on its own. I thought it might be the prestige alarm that was installed a couple months ago, but I removed the prestige brain and the problem is still there. The horns sound and the headlights flash when the factory alarm goes off, and I'll have to hit my unlock button on my factory remote to turn it off.
Anyone know what might be causing this?
Old Jun 4, 2006 | 04:15 AM
max ride 41's Avatar
MY FIRST THOUGHT IS YOU PROBABLY HAVE A LOOSE CONNECTION WITHIN THE ALARM SYSTEM. WAS IT DONE BY OUTSIDE PARTY OR DID YOU DO IT? TAKE IT BACK TO THE PERSON THAT WORKED ON IT AN HAVE THEM CHECK ALL CONNECTIONS AND DO A TEST WITH YOUR REMOTE TO MAKE SURE IT EVEN SETS WHEN YOU HIT THE BUTTON. BEST I CAN DO FOR YOU, AND YOU CAN ALWAYS HAVE THE DEALER LOOK AT IT.
Old Jun 4, 2006 | 04:45 AM
blkhawk500's Avatar
Well I installed the prestige alarm, but I removed the brain so it is not connected right now. The factory alarm came with the car.
Old Jun 4, 2006 | 08:36 AM
blkhawk500's Avatar
I noticed that there is a fuse labelled "antitheft" in the fuse panel thats in the driver's side of the engine bay. Does anyone know what this controls and if it will disable the factory alarm?
Old Jun 4, 2006 | 12:09 PM
dude88888
Open your trunk. get access to your lock switch assembly. Unplug it. See if this works. There was a TSB on this for the SE's from 95-99 with the spoiler. Water leaks down onto the switch and shorts it causing the alarm to go off.
Old Jun 4, 2006 | 05:28 PM
blkhawk500's Avatar
If this were the case, would the trunk open on its own then?
Old Jun 5, 2006 | 03:19 PM
dude88888
No. Just unplug the electrical connector. This connects to your lock assembly for the alarm only. Your trunk will still open with the key and automatically. The lock assembly I am talking about is on the trunk lid on the inside.
my03maxima
Jul 28, 2024 07:40 AM
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
