Odometer stopped counting?
Old Jun 4, 2006 | 09:21 PM
apeg's Avatar
Not to sure how to take care of this problem? My odometer and trip odometer stopped moving? I have pushed pulled giggled that black **** and I cant get anything to movie?
I did install a bezel a couple years ago so I know how to get @ the odometer, assuming I can fix the problem… how can I get the exact mileage from the ecu?? I don’t want to this car to have a “mileage tampering” asterisk next to it if I try and sell it down the line. And I can’t figure out my gas mileage anymore or know exactly when to get an oil change?
A friend of mine mentioned to me that there are a couple things on a car that the manufactured must repair for the life of the car… he claims odometers are one of them… any truth to this?
Thanks for your help
-aPeG
Old Jun 5, 2006 | 08:54 AM
MIXXMAX's Avatar
Is it just the odometer not working, and everything else is fine in the cluster? I would check the connections behind the cluster to see if anything came loose. For the odometer not moving, I would also check the speed sensor as well. Check all fuses in car, too.
Old Jun 5, 2006 | 09:50 AM
konak85's Avatar
this is a common problem with 95-96's I replaced my 96's odo with one from a 97 with about the same mileage. 95-97 are analog 98-99 -> digital. All works fine except for cruise control. don't know why.
Old Jun 5, 2006 | 12:34 PM
apeg's Avatar
perfect thanks for the help i will see if i can get my hands on one for a good price.
Old Jun 5, 2006 | 12:39 PM
Motorhead52's Avatar
If the cruise control doesnt work either than you should look at the vehicle speed sensor.
Old Jun 5, 2006 | 01:29 PM
clive's Avatar
100% chingon
The bloody ODOs get stuck on 9's, this has been a problem since Mr Benz called his first car after his daughter, or was it his friend's daughter? I forget. Mine has the same stupid problem but the number of Max's in the junkyard here can be counted on . . . well not counted at all, actually. Unfortunately for me.
Old Jun 5, 2006 | 05:16 PM
max ride 41's Avatar
mine stuck at 148,600, and then moved again a couple of times. but trip still isn't working loose connection maybe?? i found a entire cluster at a reputable parts place for 35.00 with 147,717, i think its fate man. should i check the cables b4 replacing?? thanks ahead of time>> maxride41
Old Jun 5, 2006 | 05:39 PM
maximaman10's Avatar
There are no cables. They are all electric.
Old Jun 5, 2006 | 06:52 PM
konak85's Avatar
happened right after i changed the cluster. there is no point in checking the speed sensor. maybe the cruise on 97's are incompatable with the ones on 95-96.
BTW i changed the whole gauge cluster not just the odo part.
Old Jun 5, 2006 | 07:07 PM
Maybe it isn't pluged in all the way or came unpluged when you put it back together.
Old Jun 5, 2006 | 07:20 PM
ok, then why did it work to spin mileage but trip did'nt turn?? is it a sensor or the cluster is just going bad??? the speedo works just fine, go figure.....(yes , i know that has its own sensor) thanks>>>>
Old Jun 5, 2006 | 09:21 PM
96i30azn's Avatar
... uh thats a good thing.. better resale value!
Old Jun 7, 2006 | 11:26 PM
flynlr's Avatar
same problem here for the last 2 years. it would only work when the car was cold. tried re-soldering the entire cluster that didnt help .. today I finally broke down and ordered a new gauge 225.00 including the milage set.
i told the guy at the dealer ship to add around 6k to the mileage when ordering he refused saying the could only go by what the thing said when he ordered it.
I bought the car new and will keep it till it dies so no worries about fake milage or anything like that. new odo is gonna say 35k when it should read about 42, kinda suck s having a genuine low mileage max and the odometer never lived to see 36k lol. .
Old Jun 8, 2006 | 05:55 AM
motocross416's Avatar
I've seen this happen to quite a few 95-96's, Happened to mine also, everything else worked fine, the odo, trip quit working. Check the FS forums and pick up a used cluster to put in there. Nissan charges about $50 to put the correct milege in. I had to bring both clusters in before they would do it, but it was also turning the cluster I bought forward not back
Old Jun 8, 2006 | 12:45 PM
apeg's Avatar
Well I have looked around and am able to get a 95-97 cluster @ the same mileage for a decent price, but I question getting the same cluster from a used car for replacement, I am thinking of getting the digital 97-99 so I won’t have the same problem. But what’s the cruse control issue? Does the cruse control light just not turn on or does the cruse not function entirely?
Old Jun 8, 2006 | 06:03 PM
97s are still analog. A digital one would require a ton of wiring to make it work I would think, definetly not plug n play
Old Jun 8, 2006 | 08:04 PM
apeg's Avatar
you positive somthing like this wont work?
http://cgi.ebay.com/ebaymotors/INFIN...spagenameZWDVW
-aPeG
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
