what r the best spark plug for the 4 gen?
Jun 8, 2006 | 05:44 PM
  #41
Ignition coils are a notorius problem with Maximas. Your first inclination that they need to be replaced is the Multiple Misfire code. Then you will get a hesitation and poor idle. If you car is over 70K miles and you know that they haven't been replaced, I would go ahead and save up for all six. But...if you like to fix things as they come...wait for the codes. You may or may not notice 1 cylinder misfiring...but you will definitely notice a severe drop in your MPG. You can visually inspect them or even run a meter on them...but that's up to you.
Jun 8, 2006 | 06:23 PM
  #42
Quote: Ignition coils are a notorius problem with Maximas. Your first inclination that they need to be replaced is the Multiple Misfire code. Then you will get a hesitation and poor idle. If you car is over 70K miles and you know that they haven't been replaced, I would go ahead and save up for all six. But...if you like to fix things as they come...wait for the codes. You may or may not notice 1 cylinder misfiring...but you will definitely notice a severe drop in your MPG. You can visually inspect them or even run a meter on them...but that's up to you.
no hesitation, mileage is good, and I suspect the previous owner had them changed. they should be good for a while
Jun 16, 2006 | 04:05 PM
  #43
If I run a meter on them...how do I know if they are within spec? Do I check Resistance (ohms)?
Jun 19, 2006 | 05:59 PM
  #44
ngk, Ngk, Ngk....
Jun 19, 2006 | 06:36 PM
  #45
Just NGK, it is in the manual.
