Help! Front Doors
Old Jun 5, 2006 | 06:42 PM
smackdownGTR's Avatar
Help! Front Doors
Hey All,
My front doors are getting really difficult to open and close. It started with the passenger side feeling very heavy. I didn't care too much at first, but now the driver side is the same. Does anyone else have this problem? And what did you do to fix it? Thanks for your help in advance!
Old Jun 5, 2006 | 06:50 PM
maximaman10's Avatar
Grease them with some whith spray grease and then work the grease in by opening and closeing them a few times
Dexter's Avatar
Originally Posted by smackdownGTR
Hey All,
I have same prob on rear doors, i spray some WD-40 on and it helps for a while.
Old Jun 5, 2006 | 07:51 PM
Keatz's Avatar
i have the same problem with my passenger side door, i thought it was just my max, but i guess not. I tried wd-40 and grease, but nothing worked.
Im hoping there is a solution, my friends are getting a good workout just opening and closing the door
Old Jun 5, 2006 | 08:14 PM
whitegold's Avatar
My rear doors do it, feels like it just needs grease. I think Nissan's normal service includes greesing the door hinges.
Old Jun 5, 2006 | 09:16 PM
96i30azn's Avatar
I would suggest trying to find where the friction b/c friction= wear. Therefore its not only inconvenient, its bad for your car.
Old Jun 5, 2006 | 09:33 PM
4DRSpeed's Avatar
Project Ruby......
You are correct.
My right rear door does this. I've been meaning to put some grease on the hinge, but have been forgetting about it.
Old Jun 6, 2006 | 06:26 AM
Keatz's Avatar
i guess i'll try greasing the door again, maybe i didnt grease it enough the first time
Old Jun 6, 2006 | 06:43 AM
95mtlMAXSE's Avatar
shift_Puff
use multi purpose grease on the hinges and white spray grease for that piece that goes in and out of the door as u close and open the door. I had to apply it several times to the front pass door and it work like a charm now. Been like over a year. it even did noise and now nothing Open it and close it a lot....work the grease in and keep re-applying it if need be...don't be shy with it, just clean up exess grease afterwards
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Hailstatejig
Sep 2, 2015 06:52 AM
