leaking cv input?
Old Jun 8, 2006 | 09:05 PM
YellowOne's Avatar
leaking cv input?
i have a 97 maxima about a month ago i replace the input shaft seal on the driver side because it was leaking then yesterday i noticed a leak. come to find out its from the same seal. so i'm starting to think that it's a bad differential bearing. what would you do in this situation look for another transmission or get this one rebuild?
Old Jun 9, 2006 | 02:34 AM
dgeesaman's Avatar
Maintenance Monster
Lift the car and see if that end of the axle has any play in it. (Expect some oil to dribble out when you wiggle it). That's the sign of bad diff carrier bearings.
If you are able to remove the tranny and get it rebuilt, that's what I'd do. It's not too expensive once the tranny is out of the car, and if you get it rebuilt as soon as you know it's needed. If you keep driving it something inside will break and make the whole thing worthless.
Dave
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
gigabyte
Jan 6, 2017 06:05 PM
