View Poll Results: wheel spacers, yes or no ?
Yes I have them
25.00%
No I dont
75.00%
Voters: 48. You may not vote on this poll
Do you have wheel spacers?..how safe are wheel spacers and how much is safe on a max?
Old Jun 10, 2006 | 11:44 AM
ThisMaxIsTight's Avatar
im looking at these rims that are 17x7 but have a 48 mm offset so i want them to stick out and sit flush in the rear .... how many mm's is safe on stock maxima stud?? ... whats everyone using for wheelspacers, are they safe ? .. I dont have much experience with them .. thanks for the input.. Rick
Old Jun 10, 2006 | 12:03 PM
MorpheusZero's Avatar
A little off topic, but why are you looking to get 17*7s? Can you not just stick with what you have now, or are they actually like 6.5s??
Old Jun 10, 2006 | 12:26 PM
RA030726's Avatar
I'm nutty for Nissans
I had some 7mm (i think) spacers on the rear with stock wheel and studs. I was not confident using them with my new wheels. There was not that many threads left. I would not go any larger than 5mm spacers with stock studs. They are perfectly safe when used with longer studs, and best off being hubcentric. IMO the bolt on ones with built in studs are a better choice if your wheels have clearance on the back side of the hub.
Old Jun 10, 2006 | 03:03 PM
chillin014's Avatar
yeah im planning on buyin the h&r spacers which are basically spacers with studs on them. so its like a hub extension. my wheels are like 42 offset too if i remember correctly and i need liek 20 mm spacers which i would have milled down a couple millimeters if i had room to after i get a BBK.
but 4drspeed might chime in, he has the h&r's i think.
i hate how tucked the rears wheels are
Old Jun 10, 2006 | 09:33 PM
MaximaSE96's Avatar
Maxima Owner
i have 20mm spacer with longer studs...but IMO u can 10mm without replacing them....others will say 5mm....if u feel u have enough full turns of ur lugs then do whatever...it reallly all depends on ur wheels and how much the studs stick thru
Old Jun 15, 2006 | 12:19 PM
1FSTMAX's Avatar
i was running spacers with my old rotas.. I definately didn't feel comfortable using stock studs with 5mm spacers. there was less than 1/4" of stud left after the wheel was installed to thread the nut on. I just replaced my studs with nismo ones, and took care of that problem.
Old Jun 15, 2006 | 03:49 PM
BEJAY1's Avatar
Conecarver
Remember, 9 or more lugnut turns on a 12x1.25 lug for safety.
Old Jun 15, 2006 | 04:51 PM
VQuick's Avatar
Chassis Freak
15mm or 20mm spacers for the rear only are perfect for 4th and 5th gen Maximas to make the rear track about equal to the front track. 20mm would make the rear a little wider than the front which is a good look IMO. I have 15mm and I would recommend H&R Trak+ spacers only, they are precision engineered and come with proper length studs. You could also get custom spacers made by a reputable shop but be sure to get 15 or 20mm longer studs for safety and so your lug nuts sit the same in the front and the rear.
Old Jun 15, 2006 | 05:02 PM
chillin014's Avatar
i know the rear wheels are wayyy to burried. i wish i could do it to just the rear and only a little in the front but i need that damn brake clearance for my bbk. so they are gonna be back to the same as stock once i add 20 mm to all four
Old Jun 15, 2006 | 05:31 PM
VQuick's Avatar
Chassis Freak
You could consider different rims, since rims vary a lot (even within the same size) in terms of brake clearance. What rims are you running that you have to add 20mm spacers? 16 inch rims? LOL
Old Jun 15, 2006 | 05:35 PM
chillin014's Avatar
17" centerlines. They are forged, I really like them and its just not practical to try to find a wheel I like that still weighs as light as these and is within my spending budget.
The offset is like 42. I might be able to mill the 20mm down but I most likely need more than 15 mm
Old Jun 15, 2006 | 08:38 PM
ManualMaxima's Avatar
5th Gen till she dies!
i had 5mm's when i had my old wheels, and i did not change the studs. i had a lug nut that had a extra lip on the end that gave alittle more thread, and i felt comfortable in running them
Old Jun 16, 2006 | 05:54 AM
clive's Avatar
100% chingon
What nobody mentioned is this:
Spacers increase the wear on your wheel bearings. The turning moment increases dramatically as you increase the distance from the bearing.
Old Jun 16, 2006 | 12:09 PM
that has been what i have heard, but i did not notice anything. does this increase with space size?
Old Jun 16, 2006 | 01:24 PM
clive's Avatar
100% chingon
The increased wear is proportional to the amount of spacing. If your bearings are good you won't notice anything but the life of the bearings will be reduced.
Old Jun 16, 2006 | 03:16 PM
JeremysBlkMax97's Avatar
I have been lookin for these lately, and I see that there is a vendor in the group deals section selling Eibach wheel spacers. What is the difference between the Eibachs and the H&Rs?
Old Jun 16, 2006 | 05:07 PM
4DRSpeed's Avatar
Project Ruby......
I have H&R 20MM spacers. You can't ask for a higher quality worth of wheel spacers. They come with longer studs and cool "Go Wide" stickers
Install is real easy just rather time consuming.
I have 17x7 wheels with 42MM offset. The spacers push the wheels flush to the fender and give it that aggressive look. Say bye-bye to the grandpa tucked look. I feel totally safe on these spacers. I actually torqued down the wheels to 92 for the first week and then backed it off to 84.
Here are some pictures of the spacers and stance. While the stance looks great, the exterior of the car does not 56K play dead
http://www.4drspeed.com/mycar/maxima/max004.jpg
http://www.4drspeed.com/mycar/maxima/max011.jpg
http://www.4drspeed.com/mycar/maxima/max009.jpg
http://www.4drspeed.com/mycar/maxima/max015.jpg
Old Jun 16, 2006 | 05:41 PM
VQuick's Avatar
Chassis Freak
Awwww yeah
Old Jun 16, 2006 | 06:02 PM
konak85's Avatar
^^ how many millimeters are those?
Old Jun 16, 2006 | 06:10 PM
VQuick's Avatar
Chassis Freak
8 inch wide rims with +40mm offset, no spacers on front, 15mm H&R spacers on rear.
Old Nov 16, 2006 | 09:16 AM
ThurzNite's Avatar
4drspeed: your track looks like a reverse stagger. Is it? Or just camera angle?
Also, SCCA or some other sanction require 1/4" stud thread showing beyond a lug nut?
Jae
Old Nov 16, 2006 | 10:38 AM
MaximaSE96's Avatar
Maxima Owner
i have no issues with bearings and with regular auto-x and trackdays never had an issue.....also I had mine milled down to 16.5mm from 20 so i actually have even more length on my studs...i needed them because my wheels didnt clear my brakes and 100 is cheaper than 500 for wheels
Old Nov 16, 2006 | 02:58 PM
4DRSpeed's Avatar
Project Ruby......
It's not a reverse stagger. I have 20MM all the way around, the rear just sits slightly tucked in more than the front.
Old Nov 16, 2006 | 06:22 PM
VQuick's Avatar
Chassis Freak
20mm all the way around = reverse stagger on a 4th gen or 5th gen due to the rear track being narrower to begin with. To get rid of it you have to have thicker spacers on the rear, or no spacers in front. 4Dr, your rims must have a very high offset.
Old Nov 17, 2006 | 06:22 AM
Gismo-T's Avatar
B!tch We Got a Problem
Hey VQuick, do you have pics with the spacers installed on the car? (a close-up pic)
Old Nov 17, 2006 | 09:38 AM
VQuick's Avatar
Chassis Freak
The only photos I have are here:
http://www.vquick.net/gallery/v/may06/
http://www.vquick.net/gallery/v/fall05/
Old Nov 20, 2006 | 04:51 PM
GCOBBLE's Avatar
If you get wheel spacers I hope you ruin your suspension.
Old Nov 20, 2006 | 05:04 PM
4DRSpeed's Avatar
Project Ruby......
yes 42MM . i do not like them at all.
Old Nov 20, 2006 | 06:33 PM
VQuick's Avatar
Chassis Freak
Huh, mine are 40mm, 8 inch width, and they fill the wheel wells very well.
Old Nov 20, 2006 | 06:41 PM
Russkiy's Avatar
I got a set of G35 OEM 18's. Do i need spacers for these wheels to make them look good in the rear?
Old Nov 20, 2006 | 06:52 PM
4DRSpeed's Avatar
Project Ruby......
42MM offset and 7" wide rim FTL.
Old Nov 20, 2006 | 10:58 PM
HomerMAC's Avatar
Donating i30 Owner
i had 17" altima se 2004 wheels.. with 25mm spacer in the rear sit so flush.. but when i get new tires .. all the nipples (the little stubs) that come on NEW tires.. got cut off really quick if i dove on the highway.... it sat really close to the wheel well..
but it looked great specially with the OEM mudguards..
now i have q45 wheels 2001 5 spoke polished.. and i cant put the spacer on it cause it sits out toomuch..
Old Mar 30, 2007 | 01:23 PM
felix's Avatar
Sittin' On Chrome
I have 20mm spacers on the rear wheels.
Old Mar 30, 2007 | 01:28 PM
NmexMAX's Avatar
dot dot dot ...
Ok let's just bring back an old thread
Spacers are FTW.
Old Mar 30, 2007 | 01:33 PM
felix's Avatar
Sittin' On Chrome
Spacers are FTW.
Ha ha! I didn't even notice that!
Old Apr 2, 2007 | 09:10 PM
Fr33way™'s Avatar
Wild for Width
I have 5mm spacers in the rear on stock studs.
Old Apr 6, 2007 | 08:16 AM
yehudi's Avatar
No I don't
Old Apr 12, 2007 | 07:51 PM
VQuick's Avatar
Chassis Freak
Post-*****.
Old Apr 14, 2007 | 09:49 PM
99goldmembermax's Avatar
spacers
Saw some spacers at PepBoys for approx $8.00, may be an option without spending the dough.
Cotozic
Jun 28, 2017 08:01 PM
incubusjohnny
Nov 3, 2015 05:18 PM
Slamrod
Sep 3, 2015 07:38 PM
maximusrising
Sep 2, 2015 09:55 AM
