!?P0400 Code?!
Old Jun 10, 2006 | 01:38 PM
96mAx2fast's Avatar
!?P0400 Code?!
Autozone told me it was something with the exhaust!!! I had an exhaust leak by the Mid pipe (the gasket melted!!!). I had a new gasket put in but I got the code afterwards!! Any ideas? Suggestions?
Old Jun 10, 2006 | 02:42 PM
90EightSE's Avatar
Here are some ideas and suggestions from the Nissan Service Manual (1998) pg. EC-256
Diagnostic Trouble:
Code No. P0400
0302
Malfunction is detected when ...
The exhaust gas recirculation (EGR) flow is excessively
low ...
Check Items (Possible Cause):
* EGR valve stuck closed (see below)
* EGRC-BPT valve leaks
* Vacuum hose to EGR valve clogged, cracked or improper connection.
* EGRC-solenoid valve not operating
* Tube leaking for EGR valve
* EGR temperature sensor defective
* Exhaust gas leak (Check exhaust pipes and muffler for leaks)
Overall Function Check:
Start engine and warm it up to normal operating temperature. Check the EGR valve lifting when revving engine up to 3,000 rpm quickly under no load. EGR valve should lift up and down without sticking.
Old Jun 10, 2006 | 05:32 PM
JwaxMax99's Avatar
Clean out your EGR passages. They are carbon clogged and you are getting the low flow code.
Old Jun 10, 2006 | 07:40 PM
96mAx2fast's Avatar
[QUOTE=90EightSE]Here are some ideas and suggestions from the Nissan Service Manual (1998) pg. EC-256
Diagnostic Trouble:
Code No. P0400
0302
Thanks for all the suggestions!!! Where is the EGR Valve and what does it look like?
Old Jun 11, 2006 | 09:49 AM
90EightSE's Avatar
It is located below the flexible portion of the air intake (the ribbed portion) on the firewall side. Straight back from the Engine coolant temperature sensor.
Image: http://www.car-stuff.com/nissanegrvalve.htm (no, I don't work for them).
Illustration: http://z.about.com/d/autorepair/1/0/t/9/41857730.gif (same drawing in my factory manual even though it is referenced for a Stanza in the example and I don't work for these guys either).
Off to the folks' house, good luck.
Old Jun 11, 2006 | 06:56 PM
96mAx2fast's Avatar
Thanks for all the support. I resetted the engine light by disconnecting the battery!!! It didnt come back up. I guess it's ok now. Thanks again!! If i have any problems, I'll let you know.
Old Jun 12, 2006 | 04:40 PM
90EightSE's Avatar
Wow dude. You're a genius. Next time my engine throws
a code I'll just reset the ECM to repair it. Thanks for
the info.! [laughing]
Old Jun 12, 2006 | 06:38 PM
f550maranello2's Avatar
bro i have the same code that just came up... i m trying to diagnose it....
Old Jun 13, 2006 | 05:20 AM
96mAx2fast's Avatar
If you notice, I had a pretty bad exhaust leak. That was fixed but the light wasnt reset, SO I DID IT. If its something that bad, it will come back up!!!
Old Jun 13, 2006 | 08:20 PM
90EightSE's Avatar
Settle down flame-bird. You "resetted" your light. Ok, I suspect you "hadded" an exhaust leak or something relateded" to the EGR. If your light "comes back up" now you have some "answerses". So get on with it. (BTW, I don't believe you have a full command of the English language, but whatever).
Old Jun 14, 2006 | 08:00 AM
96mAx2fast's Avatar
lol.. comedian..
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
