HELP! New Trouble Code!
Old Jun 11, 2006 | 12:24 PM
ukmastermind's Avatar
Once again i have this trouble code and i cant figure out whats wrong!
P0443: Evap Emission Control System Purge Valve C Fault
I have already changed the purge valve near the throttle body..any suggestions would be greatly appreciated!
this was replaced:
<a href="http://photobucket.com" target="_blank"><img src="http://i19.photobucket.com/albums/b168/hummerz502/26pv.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Old Jun 12, 2006 | 11:28 AM
rumpa bump.....
Old Jun 12, 2006 | 07:10 PM
oooooooooookkkk....
as i ponder what this code means and what needs to be fixed, the check engine light has turned off. Is this normal? what does it mean? has my "light" just burned out?
also, this is the 2nd occurrence for this code.....
Old Jun 12, 2006 | 09:20 PM
matt1234's Avatar
don't mean to jack your thread but I havn't posted enough to make a post and i'm not gunna spam just to get enough. I have gotten a 0314 code twice and I can't find anywhere what the hell it means. anyone have an idea?
Old Jun 12, 2006 | 10:18 PM
kil2board's Avatar
i believe there is an evap sensor also near the muffler in the rear of the car. check that one out.
Old Jun 13, 2006 | 12:55 AM
Delvin's Avatar
Originally Posted by ukmastermind
oooooooooookkkk....
What year is your car? When the system does a self check and see's that there is nothing wrong it will go out again. I had the same problem/code and changed my gas cap and it hasn't come back on in months. Try it since it really doesnt cost much.
Old Jun 13, 2006 | 09:55 AM
sorry i didnt mention this earlier: 95 SE Auto
so you had the "P0443: Evap Emission Control System Purge Valve C Fault"
code and all you did was change the gas cap??
quite bizarre...did u go w/ another OEM nissan cap or some autostore cap?
Anyone else have any ideas what this code means? I only ask b/c i need to do a smog test soon.....
thanks
Old Jun 13, 2006 | 12:49 PM
Delvin's Avatar
thanks
just make sure you reset the light before you go through the test most likely it will pass.
Old Jun 13, 2006 | 10:58 PM
so no one else has had this problem??
still have no idea what else i need to troubleshoot.
Old Jun 14, 2006 | 08:15 PM
docj's Avatar
I haven't gotten this specific code, but I have gotten a bunch of other EVAP codes. I wish I had some info for you. All I have been able to find is that you should check the lines. There seems to be a general lack of knowledge about this, or else it's too difficult to explain online. I just checked my lines, nothing obviously wrong, cleared the codes, and it drives fine. But now there is a whine from the canister. No idea. If someone knows about the EVAP system I think the how to section could use some help in that area.
Old Jun 14, 2006 | 09:54 PM
Delvin's Avatar
EVAP systems are a complicated thing. The reason I replaced the gas cap on mine is because I asked two different master techs what the problem could be with that code and they both told me it can be almost anything and that 99% of the the fault thats triggered is caused by something else. I've noticed in general with Nissans with that code its either the valve at the canister in the back or the gas cap.
Oh yeah I got one from the stealership but I get stuff at wholesale cost so I have no idea what it would cost regularly.
Old Jun 14, 2006 | 10:06 PM
urmab's Avatar
I have the exacly the same code, Ive replaces the fuel cap the condecer, purge valve, the code is still there I tend to ignore it now.
Old Jun 15, 2006 | 12:58 AM
well i've replaced the main valve...traced and folloed all vacuum lines..no leaks..
no idea... the light just bugs me...gotta find out whats up
btw there is a metal sounding rattle that occurrs randomly when i accelerate..any ideas there?
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
