led ***PICS***
Old Jun 15, 2006 | 06:06 PM
200kMax's Avatar
led ***PICS***
as promised
DOOR LED's
DOOR LED's
Speedo
The pic is showing fades of blue. Behind the wheel, it looks a LOT better
Climate control
all shots using slow shutter w/ no flash on a nikon d70 slr. best way to capture low light..
Old Jun 15, 2006 | 06:09 PM
200kMax's Avatar
the step lamps are using 4 3mm led's.
the climate control has i believe 3 led's. their is a slight hotspot on the 3 setting as ive seen w/ all led climate control mods. i never did the a/c led. thats why its dimmer.
i also wired my dome light w/ a set of 10 led's. those are bright.. *no pics*
G4nismo's Avatar
very clean me like
Old Jun 15, 2006 | 06:30 PM
4x4Max's Avatar
looks very nice, how hard would you say the project is for somebody who doesn't have experience but has a solder?
Old Jun 15, 2006 | 06:43 PM
WielkiWaac's Avatar
MaximaDriver
looks good.
i wish i had some extra time to do leds in my car
Old Jun 15, 2006 | 06:44 PM
G4nismo's Avatar
i've done everything he's done. very easy, just need to know how to remove the trim pieces and such and patience
200kMax's Avatar
this is not a job that you can complete easily.
1st, the parts u are dealing w/ are small
2nd u need to angle the bulbs into small angles.
3rd, a LOT of trial and error to make sure u have no hotspots.
so now, let me get w/ the basics. sand all your led's. this will reduce *hopefully eliminate* any hotspots.
2nd, make sure u dont cross any of the led leads. especially when working w/ 3 mm led's. use shrink tubing on all the led leads.
also, make sure u use resistors for everything. when i wire a single led, i use 470 ohm led's. when i wire 3 in series, i use 150 ohms.
the doors were quite easy. maybe 2 hours total. the climate control was a bit harder. maybe 3 hours.
the instrument cluster was definitely the hardest. many many hours.
Old Jun 15, 2006 | 07:06 PM
4x4Max's Avatar
that sucks, becuse the instrument cluster is what i mostly wanted to do...i guess i'll do some reading on it and try it, thanks!
Old Jun 15, 2006 | 07:13 PM
JNCoRacer's Avatar
Just the tip.
No LED in the temp control slider?
Old Jun 15, 2006 | 07:25 PM
Keatz's Avatar
man that looks sweet, me like a lot
Old Jun 15, 2006 | 08:34 PM
ManualMaxima's Avatar
5th Gen till she dies!
nice and clean man, i like your gauges
Old Jun 15, 2006 | 08:50 PM
ethnic6's Avatar
that looks awesome, I'm not adventurous enough to mess with my needle... lol, don't know that much about electronics...
Old Jun 15, 2006 | 09:57 PM
Eyemfaster's Avatar
red x's for me
Old Jun 19, 2006 | 05:10 AM
devast8's Avatar
do you know where I could buy the same LED's you used?
Old Jun 19, 2006 | 04:46 PM
200kMax's Avatar
http://cgi.ebay.com/100X-UltraBright...QQcmdZViewItem
PLENTY OF EM on FLEA-BAY
Old Jun 19, 2006 | 05:37 PM
aznprid972's Avatar
I was about to mention the same thing. It is really easy as the orginial one is already an LED so it's pretty much a direct desoider/resoider. 3mm led fits perfectly in there.
Also the climiate control lights (the little ones that shows you which one you selected) is pretty easy to do as well.
By the way, why does your guages shows "fades" of blue as you stated. I put some hyper white bulbs behind mine and 2 of the guages light up a tint of blue as well. I'm guessing there's no way around it?
Old Jun 19, 2006 | 06:39 PM
VTonmymind's Avatar
Mmm, fresh lobster
very nice. Do you plan on changing the color of your clock?
Old Jun 20, 2006 | 03:51 AM
200kMax's Avatar
yeah, just didnt think about the a/c bulb when i did it. *stupid me*
the shades of blue are due to camera being at a low shutter, but was not low enough. the lower it is, the more white it captures. in reality it is a hint of blue all around. i rather have it all white. but the se stock gauges have a blue film on the back that i cant remove.
Old Jun 20, 2006 | 04:25 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You're off to a good start, young Jedi.
Old Jun 20, 2006 | 08:12 AM
Spartuss's Avatar
looks good.
Old Jun 22, 2006 | 06:24 PM
Hexon's Avatar
I am not brave enough to take out my clock and gauge cluster or I would do it. I would like to install something brighter in my clock so I can see it when the sun is really bright. With my windows tinted, its a little better but still, when I open my sun roof I can't tell what time it is.
Old Jun 22, 2006 | 07:59 PM
kcryan's Avatar
What would happen if i just put Blue LED 194 bulbs in my gauge cluster? how would it look?
Old Jun 22, 2006 | 09:37 PM
wariow's Avatar
good start padawan. slider is easy, u don't even have to remove the whole unit again, just pull off the slider and you shoudl see a thin green LED, yank that one out and take a 3 mm led and use a file to shave down the sides so the fit and cut the leads so they're the same length as the green one. Just insert back in and if it doesn't work, flip it around and it should work.
Old Jun 23, 2006 | 03:39 AM
darklegend06's Avatar
wow that looks nice. I wanted to do something with LED like that but didn't have the time to do it.
Old Jun 26, 2006 | 01:05 AM
Thahman's Avatar
Damn, looks good. I like the way the instrument panel looks...
Old Jun 26, 2006 | 04:22 PM
urmab's Avatar
Looks really good how you able to get rid of hot spots?
Old Jun 26, 2006 | 05:35 PM
dko's Avatar
dko
duck and cover
pure hotness
Old Jun 26, 2006 | 06:18 PM
200kMax's Avatar
believe me, its not very easy.. a lot of trial and error. but generally, u want to avoid direct led lite to the numbers on the dial, and angle it a bit off center. and a must is u have to sand the led..
Old Jun 27, 2006 | 10:20 AM
Thahman's Avatar
Anyone wanna make an LED 99.5 Instrument panel for me? :-P
Old Jun 27, 2006 | 10:27 AM
2 MaXiMuS 4's Avatar
Maxima.Org's Official Lurker
sandpaper is your friend...
Old Jun 27, 2006 | 01:22 PM
maxprivate's Avatar
Black Lion
led gauges
I Just completed mine sorry no pics. i used blue leds for the fuel and temp gauges, and white for tach and speedometer. This mod is very tuff and time comsuming on top of that i messed up my speedometer i guess being to ruff with it. Now i need a new speedometer, very tuff to set the led in position with the analog speedometer there is to much in the way to set it perfectly my tach is way brighter cause i was able to get the led right in the middle of the gauge.Anyone attepting this mod, get ready to spend a lot of time on it.
Old Jun 27, 2006 | 03:17 PM
D-Bo's Avatar
Droppin logs
Looks good, I really need to get off my **** and put my LEDs to use...
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
