Premium 93 octane huh?
Another data point:
I've been running 89 octane for a couple of months now, and I've seen no decrease in fuel economy. (I always scribble the mileage down on my gas receipt and put it into a little spreadsheet, so I *know* what my fuel economy is). No knock sensor codes either.
Interestingly, I've found that avoiding running the A/C save a good bit of fuel. I run the auto climate control at 77 in summer, and in winter I make sure to switch from defroster to heat asap. I used to run it in heat/defrost all winter long and my fuel economy suffered.
Dave
Dave
Originally Posted by Nismotic
I would suggest to do some reading of previous threads. Donating will allow you to use your search function.
And if you're contemplating on a few cents for the health of your ride, you shouldn't even consider modding your car.
Good point ....
Originally Posted by zander
Honestly if the 7-10 dollars a tank is going to break the bank I would suggest selling the car and getting a small 4 banger, or maybe even a bike-cycle. Get a honda insight or something and not have to worry about gas prices
Originally Posted by NmexMAX
Some people on here are not average drivers.
Originally Posted by dgeesaman
Another data point:
I've been running 89 octane for a couple of months now, and I've seen no decrease in fuel economy. No knock sensor codes either.
Dave
Dave
Holy crap, another gas thread.
Who gives a rats azz. Use regular if you wish or use premium if you wish. Write about how regular is the greatest or write about how premium is the greatest.
I use premium because that's what the car says is the best for best performance. If you want to nit pick or distrust or give reason why that's wrong so what.
I choose to spend 20 cents more per gallon and you don't. I choose to spend 20 cents less per gallon and you don't. So the fukk what.
In the grande scheme of things WHO GIVES A ****!!....
Originally Posted by nelledge
I agree that these gas threads are frustrating, but Wow! You ever thought of enjoying a nice, relaxing cup of tea?
Somebody crapped in my cornflakes this morning I think....
agreed.. (sips a cup of green tea.)
haha use whatever you want.... i choose to use 93, it may do nothing, and even if it be proven to do nothing someday, I dont care, I still feel like im doing better for my car by running the BEST there is. Because thats all my baby deserves... the best. BP 93 FTW!
I spent 80 bucks on plugs when I could have spend $40... I spent almost $100 for a o2 when I could have spent $60.... My car is just not something I go cheap on. You want to save money, skip that fast food your about to pick up. Thats the 7 bucks right there that you cut your car out of.
I find it funny when people are loyal to a name brand of gas station. How many big name stations are there in your market? I've never counted, but there's Hess, Shell, ExxonMobil, Conoco, Marathon, Sunoco, the list goes on depending on where you live. I suppose about a dozen or so anywhere you go. Now, how many oil refineries are there that serve your market? Probably one or two, again, depending on where you live. Your fuel is made at the refineries, not the stations. The refineries give every one they serve the same fuel. They all sell the same thing. The same truck delivers to many different name brand stations. Now, there could be differences in business practices that are worthy to support, but not differences in quality of fuel (of comparable grade).
Originally Posted by MIXXMAX
Our Maxima's require premium, bottom line! Run anything lower, and eventually you notice a difference in performance from your car, let alone of possible knocking noise from the engine. Down here in PA, we have as high as 94 octane (Sunoco). I only run 93 and never will put in anything less, even if gas prices are high. I don't want to spend more money down the line in replacing parts in my car from running lower octane. Just my $.02.
As far as the gas debate goes I just use whatever the car company recomends
Correlations. Remember correlations. And knock sensor will constantly adjust itself without throwing a code. No code does not = 'perfect running engine'. Very important to know what's happening with your engine without solely relying on codes. My $.02.
Dave
Originally Posted by Wetballoon
The refineries that you refer to are terminals, fuels are pumped into the terminals via the pipelines. Remember last years "shortage" after Katrina? Many pipeline pumps lost power. When the tanker driver load up at the terminal, they select the grade of fuel and the supplier, and the brand name additives are added to the fuel while it is being loaded. Whether you choose to believe it or not, there is a difference in brands. And if you compare the color of Amoco Ultimate it to any other gas, you will notice the ultimate is clear, not yellow.
The only fuel *I* place additional value in is Sunoco 94. I figure because they blend it with 87 at the pump to make the 89 and 93 grades, and because nobody else makes the 94, that I'm less likely to be given crap gas (lied to). And I only buy the 94 for my turbocharged RX-7, where low-grade gas will blow your engine, rather than trip some weenie knock sensor code or retard your timing for a week. The Maxima gets fuel from whatever pump is cheap and convenient.
Dave
As long as I continue getting 25-26mpg on my commute, and it doesn't show any other symptoms, I don't care about any supposed performance loss. Dave
The 'value' of a Maxima with 149k miles is insignificant compared to the cost of fuel.
Dave
Dave
What's a knock sensor?
its the sensor that activates ur alarm when u knock on the window........and its recommended to use Premium fuel....is it required....no ....ur car may run like ***....and ur knock sensor MAY have premature life....but do as u wish
Bottom line, our Max's are optimized for 93 octane, don't cheap out by using 87 or 89 just to save a buck or 2.
If you want a more thorough explanation on why our Max's need 93, I suggest, as most already have, to read the FAQ's
This thread needs to be
Who here has talked about mods? Not the original poster. Not me. And I challenge you to find someone who has sacrificed the OVERALL LIFE of their car to lower octane gas. Nissan would be out of business if gasoline grade affected overall life of thier car. People perhaps sacrifice MAXIMUM performance (much more than a driver would ever notice on a day-to-day basis), but that's it. 100 years of vehicular evolution in the technology age protects the consumer from the demons within the lower priced fuel grades.
When I discuss my preferences for lower priced fuel, not only do I quote my real life experiences, but I share the raw data with everyone here. I encourage anyone who has any form of empirical data confirming that high octane fuel will be better for the average driver over the long run to please share it.
Collect the pennies you've saved by using less than premium to donate 20 bucks in order to use the search engine. I've seen diagrams, graphs, equations, chutes and ladders, etc on this stupid topic. In my preference, I will spend the extra few dollars to help me sleep a little better.
You don't have to challenge me to anything. If you want to save a few bucks on your vehicle, be my guest. It's not like Nissan Engineers know wtf they are talking about anyways
It seems like the longer I'm on this damn site, the more defensive people get when it comes to saving money. This reminds me of the thread where the guy bought a tornado and really thought it worked. God forbid.
I use 93 octane. 93 has a better resistance to pinging since it combustes less easily. Also, it's not that big of a price difference once I fill up anyways so I go all the way. 93 is $2.89 here in TN.
Dave
I just dont see the point in buyin a car you cant afford the gas for. I have never put in anything less than premium (i have 93 out my way) and i wont regardless of the age of the car. And its not just maxima owners doin this, i see you guys are makin coments about doin that to beemers... sadly (i work for a gas station) i have bmws, mercedes, tls, and so on that come in all the time and buy regular. Its funny its the people that have the mercedes that complain to me the most at work about the price... first i could care less about the price, second i could care less how people feel, third Kia's have great gas milage lol.
There is another issue: when the truck arrives at the gas station, the manager instructs the driver how much of which fuel to put into which storage tank. A guy I know who drove tanker trucks said he had a disturbing number of managers instruct him to put 87 or 89 in the 93 tank, and so on. He would deliver to all different chains too.
good god, i've always run 87 in all my cars. never noticed a difference at all in gas mileage or performance, sheesh. i thought it made it run better, but it was a mind control thingy( placibo?? ) that made me think it ran better. keep your fluids fresh, and fix stuff when it breaks, not rocket science< you know??
it's the knockoff of the Xbox 360.
And when you multiply 20 cents per gallon, it's 3.70, not 7, not 1, not 2.
People are so one-sided here they get the facts wrong, and then they continue to insist on the same position without even thinking about what they are saying.
Can the Maxima benefit from 91 octane over 87 octane?? YES. Can a CR-V? NO. Can an Avalon? YES. Can a BMW? YES.
Does it cost only $7 more per tank for super? NO. It costs about $3.70.
Can it be concluded that a person who uses regular is cheap, or can't afford to use super? NO.
Is super relatively cheaper today than it was in 2001? YES. When you think about it, 0.20/3.199 is only 6.25%. That's relatively cheap. The absolute marginal amount is basically unchanged.
Sometimes I can't understand why facts aren't important on this forum. The only thing I can possibly think of is the age factor.
Originally Posted by Frank Fontaine
The sheer comedy of these threads is how the facts get twisted and more twisted....
Sometimes I can't understand why facts aren't important on this forum. The only thing I can possibly think of is ...
Originally Posted by Scooobay
they money you'll save using reg you'll lose MPG and have to fill up more with less performance....BLEH...
JoshG
51
Sep 21, 2015 10:41 PM
