engine stalling while at red lights
Old Jun 21, 2006 | 02:09 PM
Smoothb2002's Avatar
hope somewone came across the one b4, the car is sputering/chocking while driving and at red lights, everyone in a while it will turn off. one mech said it was the fuel pump, and another said it was the gas filter, both mech did not get anything from the computer.
If anyone has any ideas please respond.
thanks in advance for your help.
one
Old Jun 21, 2006 | 02:40 PM
DcMaN's Avatar
start with the basics, clean out the Throttle body, Clean the Idle air control valve, then work your way towards new plugs, fuel filter stuff like that. Good luck
Old Jun 21, 2006 | 05:49 PM
killerVQ30DE's Avatar
one
Is it cold when this happens? Could be your ECTS (engine coolant temp sensor)
Old Jun 21, 2006 | 07:04 PM
gtmuggs's Avatar
check this link out
check this post out it might help you out some
http://forums.maxima.org/showthread.php?t=473170
Old Jun 24, 2006 | 10:55 AM
thanks for the info will start on it right away, and thanks for the thread.
laters
one
Old Jun 24, 2006 | 05:46 PM
billfromtr's Avatar
I had the same problem with my 95. Noone could diagnose it. I finally took it to a dealership and they fixed it. It was some wiring harness. apparently there was a not a recall, but a bulletin that nissan knew about.
Old Jun 24, 2006 | 07:09 PM
Tryonetic's Avatar
wow, the dealership can actually fix stuff, that's amazing!
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
beboski
Aug 16, 2015 05:23 PM
