Why are both my cooling fans on all the time???
Old Jun 23, 2006 | 03:45 PM
csb's Avatar
csb
'97 Max SE 5 spd. Actually, not ALL the time...they both turn on, simultaneously, approximately 30 seconds after my car is started...then, they don't turn off (unless the car is turned off). A little history: thermostat replaced w/ coolant flush...normal temp. gauge, car runs perfectly, A/C works perfectly, new coolant temp. sensor, checked/swapped all relays under hood, unplugged/blew out fan plugs. The local Nissan dealer is stumped, as is my local mechanic. Please help...I'd like to get this straightened out b4 I leave for a road trip (on Sunday). The air temperature today is approximately 85 deg F, if that helps. If I drive at highway speed for, say 10 miles, then pull over and check on the fans, they're both spinning and don't stop. This can't be normal. Thx in advance...
Old Jun 23, 2006 | 03:51 PM
NmexMAX's Avatar
dot dot dot ...
They turn on afer the coolant temperature reaches 200-205 IIRC.
Seems like a faulty sensor.
Hey, your car is running cooler!
Old Jun 23, 2006 | 04:51 PM
njmaxseltd's Avatar
A/C compressor on = fans on
Auto climate control set to AUTO will run your A/C compressor when temps are above freezing, which will also make the fans run.
If thats not whats going on, you may have a stuck relay or a faulty engine coolant temperature sensor.
The Haynes shop manual will help you trouble shoot your car.
Old Jun 23, 2006 | 06:50 PM
csb's Avatar
csb
Thx...as I mentioned in the initial post, I replaced the coolant temp. sensor (today, actually...made no difference) and the thermostat. Also, I'm aware of the fact that both fans run when the A/C is on. I've tried switching relays back and forth and, regardless of which relay is in place, both fans still run. Any other ideas, fellas?
Old Jun 23, 2006 | 06:53 PM
clive's Avatar
100% chingon
There are two different temp sensors. One controls the ECU - that's the ECT sensor. The other controls the fans. I think it's the latter sensor you should check.
Old Jun 23, 2006 | 08:35 PM
csb's Avatar
csb
Really? Where exactly is the sensor that controls the fans located?
Old Jun 24, 2006 | 03:43 AM
njmaxseltd's Avatar
The ECT sensor sends a signal to the ECU telling it engine temperature.
The ECU turns the fans on and off depending on engine temp.
The other coolant temp sensor only operates the gauge in your dash.
Matt93SE
May 24, 2019 02:58 PM
MattWithTheMaxima
Jun 30, 2017 01:06 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
Carlos Levy
Aug 23, 2015 08:48 PM
Balkins
Aug 12, 2015 06:39 AM
