Is "BOMZ Racing 3" inlet Cone Air Filter" any good?
Old Jun 24, 2006 | 11:30 AM
stas29's Avatar
This item sells on ebay very cheap compared to K&N filter kit. Do you know if it's any good? For $22 shipped I think it's a good deal and sure beats stock air intake. Any ideas?
http://cgi.ebay.com/ebaymotors/ws/eB...9327%26fvi%3D1
Old Jun 24, 2006 | 10:18 PM
99grnmaxgxe's Avatar
It's cheap b/c it's a crappy filter, and the stock intake is better than this setup, this is known as a HAI=hot air intake, the stock sucks in cooler air comapared to this one which sucks in hot @$$ engine air. If you like the looks in your engine bay and a bad @$$ sounding car, get it. I have something like this and I love the sound and how it looks, but remember these make you lose some low-end torque.
Old Jun 24, 2006 | 11:35 PM
Cdg2125's Avatar
As 99 said its actually not better than your stock intake. If you have extra performance upgrades then sure get it. It'll give a nice sound to the car. But otherwise it will only give sound and drain some of your low-end. Either go with a Place Racing or wait till you have more hp.
Old Jun 25, 2006 | 07:48 AM
1996blackmax's Avatar
You get what you pay for......
Old Jun 25, 2006 | 08:59 AM
stas29's Avatar
So, I may as well save some money and buy myself a K&N Cold Air Intake Kit to get some aditional HP on my bare stock 97 Max SE.
K&N Also makes a rectangualar filter that is designed to be a direct replacement for a stock filter. Even though it does not have as much surface area for filtering air compared to a cone shapped filter I think I will just lose < 1 HP and the growling sound.
Any ideas?
Old Jun 25, 2006 | 09:22 AM
d00df00d's Avatar
Old enuf to pick his own gears
It's from a company called "Bomz Racing".
Think about that for a second.
Old Jun 25, 2006 | 09:37 AM
Any ideas?
If you want a CAI, get an eBay one and use the pipe but buy a good filter like K&N and put it on. I have the K&N panel filter (rectangular one) and it doesn't do crap. Here's an example of a CAI http://cgi.ebay.com/ebaymotors/95-99...01066356QQrdZ1 just use the pipes and get a different cone filter.
Old Jun 25, 2006 | 09:41 AM
stas29's Avatar
I know. It must be the bum!
Old Jun 25, 2006 | 09:59 AM
Cdg2125's Avatar
It's not that bad it just wont give you any extra power. I dont thnk K&n makes a CAI for our car. Go with a place racing intake anways. It's the only true CAI.
Old Jun 25, 2006 | 10:00 AM
stas29's Avatar
The auction on ebay claims that I will gain 10-15 HP's from the cold air intake kit. Is this statistical or theoretical.
Old Jun 25, 2006 | 11:05 AM
densetsu's Avatar
just run some mesh over a pipe, it will sound better and flow more air.
Old Jun 25, 2006 | 06:40 PM
Cdg2125's Avatar
It's trying to sell it. It's a HAI basically, meaning its sucking hot air from the engine bay. To gain horsepower you need colder air in the intake. You will not gain anywhere near what they say. You'll lose low end power and maybe get a little high end power. That's it. It's really for the engine bay look and the sound, not the power.
Old Jun 25, 2006 | 08:01 PM
d00df00d's Avatar
The length and design of the intake are equally important.
If you want low-end grunt, you need a long intake tract so that you have a big column of air that can build good momentum.
If you want high-end power, you need a short intake tract to suck in as much as possible, as quickly as possible.
Either way, you want your intake tract to be as straight and smooth as possible. And of course, cold air helps everything.
Old Jun 25, 2006 | 08:05 PM
d00df00d's Avatar
BTW, the stock intake is NOT restrictive, and it certainly draws colder air than most systems you can buy.
Old Jun 25, 2006 | 08:51 PM
Cdg2125's Avatar
I agree dOOdfOOd. Didnt think about the length before. good call. And yes, most of the intakes are worse than the stock intake.
Old Jun 26, 2006 | 07:03 PM
stas29's Avatar
So, by purchasing the el-cheapo CAI from Ebay I will actualy loose power becuase the kit sucks in more hot air and less cold air, right?
For $33 shipped I think it will do more good than harm to my aging 97 Max with 90k miles. I'll just save money for now and buy 02-03 fully loaded max SE (hopefuly soon)
Old Jun 26, 2006 | 07:24 PM
Max_Out's Avatar
Under the radar
I have the bomz intake, and i thought the same about how much hot air was going into my engine. but on a 90 degree day in traffic cruising at about 60 mph the air intake temp was 82 degrees. so its not as hot as you think.
Old Jun 26, 2006 | 07:26 PM
d00df00d's Avatar
Your intake air temp was lower than ambient air temp?
Old Jun 26, 2006 | 07:52 PM
Cdg2125's Avatar
Well yeah when you are moving the air temp is cooler because of air flow. But that tempature air would still do better on your stock intake at the point. If you have no other performance upgrades then the intake is still going to effect your power.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
95Maxi
Aug 29, 2015 09:38 PM
NissLover
Aug 22, 2015 10:26 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
