Finally Got A Code 0605
Old Jun 29, 2006 | 07:15 PM
seanish4042
which is cylinder 4 misfire.
so now what should i do? should i test ignition coil? replace it?
Old Jun 29, 2006 | 07:46 PM
TurTLe*'s Avatar
there is only oh so many options.
first off, how old are your plugs? dirty plugs might cause a misfire. a misfire CEL only shows up after 14 misfires. And in one minute there is about 50 sparks.
most like its just a coil tho. people on here are selling for like $20 a peice. I would possible consider changing plugs as well if you haven't copper plugs are 2$ a peice at most auto stores.
If you replace that coil and your plugs and you still get that fault look at the wiring to the coil.
Old Jun 29, 2006 | 10:59 PM
xlr8r's Avatar
most likely is dirty/worn plugs.
sounds like general maintenance problem - might be worth an oil change and air filter too.
maxinout93
Oct 31, 2015 02:04 AM
salty318
Sep 29, 2015 01:21 PM
