Bad clutch line on 4th gen
Old Jul 1, 2006 | 05:23 PM
Loren00Miata's Avatar
I discovered yesterday that my clutch was sticking. I checked my clutch master cylinder and it was almost empty. I filled it up and inspected the car, but could only find a small amount fluid on the front line. It appeared to be a very slow leak, so I was driving around the car today. In a short drive across town, my clutch was having problems disengaging. I checked the master cylinder and it was already halfway down. I got someone to let me borrow some brake fluid to fill it up again and drove it home.
I drove my other car over to Courtesy Nissan to get a line and a slave cylinder. Butch, at the counter, told me that he has been selling a lot of the long flex lines that go to the slave cylinder and doubted the slave cylinder was bad. It took about an hour to change the line and bleed the clutch. All seems fine again. I have never heard before that this is a problem, so I am curious who else has had the same problems. BTW, my 97' only has 66K miles on it.
Loren
Old Jul 1, 2006 | 05:50 PM
ThurzNite's Avatar
I had that problem. Fixed now. There's a group deal going on for stainless steel lines, and many have bought into that. Wonderful, but hard to get the stats you're looking for since they all changed out the stock part before it failed. I'm glad you're safe; not having clutch sucks.
Jae
Old Jul 1, 2006 | 05:52 PM
ManualMaxima's Avatar
5th Gen till she dies!
do you think it could be messed up, but not leaking, cause i have replaced my clutch, slave, master cylinders and my clutch still feels like crap and is sticky sometime. alot of time it falls to the floor anad i have to kind of pump it...
Old Jul 1, 2006 | 06:34 PM
Wetballoon's Avatar
Mine went bad a while back, but lasted longer than yours. drove it around for a bit, but frequently topped off the master cylinder. All is good now.
Old Jul 1, 2006 | 09:41 PM
4x4Max's Avatar
mine's leaking too, i have a SS one but havent had the time to replace it
Old Jul 2, 2006 | 08:38 AM
JeremysBlkMax97's Avatar
I bought the SS clutch line from Derrik, made by Technafit, about two years ago on here, and I just got around to putting it in yesterday. With the ACT stage 1 and 116000 miles on the odo, my clutch would chatter when moving slowly and slipping the clutch. Now I feel like the pedal modulation is much more controlled and the chatter has also been reduced. Mine wasn't sweating fluid yet, but was definitely flexing due to it's age. Easy mod to do, and you won't have to worry about it again.
Old Jul 4, 2006 | 11:27 AM
gtmuggs's Avatar
where can i get this clutch line from and is ther any post of how to put it on?
Old Jul 4, 2006 | 02:13 PM
99se5speed's Avatar
SHIFT_up
^^ http://forums.maxima.org/showthread.php?t=338081
I haven't seen a write-up on installing it. Althought there might be.
Old Jul 4, 2006 | 07:48 PM
Apparition's Avatar
Ichiban King
that sounds like a bit more than a minor problem lol..
Old Jul 5, 2006 | 09:39 AM
SHIFT_*grind*'s Avatar
I just bought my Max, which had a clutch job done on only a day or two before I got it (new disc/pressure plate/flywheel polish). The clutch felt fine, but after running a while on the interstate it got *really* mushy; it would go down to the floor and I still wouldn't be able to put it in gear. It was like that sporadically during the 4 hour freeway trip home, but since then, just driving around town, it's been fine.
Air in the lines, perhaps?
Old Jul 5, 2006 | 09:54 AM
geo1317's Avatar
i just replaced mine with the one derrik sells, it fixed the problem and the clutch feels better to me as well.
some info and how to's:
http://www.motorvate.ca/mvp.php/802
http://www.vqpower.com/v2/modules.ph...howpage&pid=67
Old Jul 5, 2006 | 10:02 AM
matty's Avatar
Why spend $70 on a rubber line from Nissan when you can get a SS line from the group deal section for $25 and have a better feeling clutch.
-matt
maxima-junky
Oct 21, 2015 05:17 PM
Finkle
Sep 27, 2015 09:53 PM
FlaMark
25
Aug 28, 2015 10:15 AM
maxima-junky
Aug 13, 2015 09:59 AM
MikesChevelle
Aug 10, 2015 10:53 AM
