brakes using the speed bleeder - done but
Old Jul 1, 2006 | 10:05 PM
joew's Avatar
i just bleed my brakes using the speed bleeder and it feels soft. i have not bleeder my brakes since i bought my car new 97. using speed bleeder is striaght forward. is what i am feeling is normal? is it possible that i had the nipple too lose? what do you think?
Old Jul 2, 2006 | 04:37 AM
dgeesaman's Avatar
Maintenance Monster
It is possible you had it too loose. You want to crack it just enough that it bleeds fluid, and no more. If you have a helper, it might be good to do a couple finish pumps at each corner while manually opening and closing the bleeder under pressure. So if you're sucking in a little air, manually opening the bleeder should stop it.
The good news is that a slightly soft pedal is better than really old / dirty fluid. I've bled my brakes numerous times and for some reason it never seems firmer.
Dave
Old Jul 2, 2006 | 07:36 AM
ThurzNite's Avatar
slightly ot: how much and where did you get the speed bleeders?
Jae
Old Jul 2, 2006 | 08:52 AM
dgeesaman's Avatar
Maintenance Monster
www.speedbleeder.com
Old Jul 2, 2006 | 09:08 AM
joew's Avatar
thanks buddy.
Dave
Old Jul 2, 2006 | 09:10 AM
joew's Avatar
your local autozone has it. the brand name is russell that comes from speedbleeder. they all come from the same place.
Jae
Old Jul 2, 2006 | 09:13 AM
MaximaSE96's Avatar
Maxima Owner
yea u prolly had the bleeder open to much,..,all u need is like a 1/4 turn...i usually do 2 manual bleed to finish off
Old Jul 2, 2006 | 09:44 AM
joew's Avatar
ok, while bleeding with the speedbleeder, should you feel resistance on brake pedal or should the pedal be soft?
Old Jul 2, 2006 | 11:58 AM
dgeesaman's Avatar
Maintenance Monster
There should definitely be some resistance while pumping, but not as much as braking.
Dave
Old Jul 2, 2006 | 03:04 PM
ThurzNite's Avatar
Ouch, both speedbleeder.com and kragen has them for retail price.
I recently had a problem w/soft pedal. I did 2 things: bleed the master cyl, and bed-in the pads. Try those.
Jae
knight_yyz
Nov 1, 2015 01:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
