Getting My Clutched Changed..What Else Should i replace?
Old Jul 3, 2006 | 10:21 PM
Scooobay's Avatar
Hey,
Hey guys, im getting my clutched changed on wednesday, ordered myself a new 5th gen clutch kit from Dave b. the parts guy ( Excellent Class A Guy ). Since im doing this im curious, what else should i order and replace at the same time? im putting in an order for SS clutch lines and some Redline Mt-90 after i finish this post..what else should i purchase? im looking for definite smooth shifting.
Old Jul 4, 2006 | 04:42 AM
BEJAY1's Avatar
Conecarver
Short shifter? Poly shifter bushing? Lightened flywheel while you're in there?
Old Jul 4, 2006 | 04:50 AM
Nealoc187's Avatar
SLOW
buy two new axle seals incase you rip one up while removing or reinstalling the transmissions.
Old Jul 4, 2006 | 05:50 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
one word......FIDANZA
Old Jul 4, 2006 | 06:50 AM
Scooobay's Avatar
I wa gona buy one. but due to funsand how quickly my clutch burnt out I didn't have the funds for it, I guess I'm just gonna resurface my current flywheel.
Old Jul 4, 2006 | 06:54 AM
xlr8r's Avatar
too obvious but.... throwout bearing?
Oh... and the sway bar bushings. The best $10 anyone can spend!!
Old Jul 4, 2006 | 06:56 AM
xlr8r's Avatar
what condition is the clutch hydraulics in? new rubbers & hoses there too?
Old Jul 4, 2006 | 07:56 AM
maxgtr2000's Avatar
KH3 by popular demand
The rear main seal while you are in there.
Old Jul 4, 2006 | 10:33 AM
99se5speed's Avatar
SHIFT_up
+10 on that.
Old Jul 6, 2006 | 09:29 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Resurface the flywheel.
Old Jul 6, 2006 | 10:57 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Replacing the RMS is a lot of work, especially if you've never done it before. gotta pull off the upper pan. Not worth it unless its leaking real bad.
Old Jul 6, 2006 | 11:05 AM
xxtavixx's Avatar
I wish people would just answer a question sometimes...
Clutch disk
Pressure plate
rear main seal
axle seals (2)
throw out bearing, make sure to put some grease on the shaft
resurface the flywheel. I'm not sure if it's two stepped or one.
Now, make sure you thread lock the flywheel bolts. If you do not, oil will seep through the threads. Also make sure you perfectly align the disk, otherwise you will have a rough shifting mechanism and some chatter when you let the gear slow you down.
-Andrew
Old Jul 6, 2006 | 11:12 AM
matty's Avatar
Pull off the Upper Pan ?? No you dont. The rear main seal is in clear view when you pull the transmission off of the car. Get a new one from Nissan, and install.
-matt
Old Jul 6, 2006 | 11:13 AM
xxtavixx's Avatar
The funny think about rear main seals is they don't usually 'leak'. They are not pressurized, therefor they typically don't progress like that. They let go all at once, I'd rather replace it while I was there.
-Andrew
Old Jul 6, 2006 | 11:21 AM
maximadriver198's Avatar
I having some problems with the my 2000 max. I'm thinking that there could possibly be a problem related to the stage 1 nismo clutch that I put in 3 months ago. From time to time, I will have problems putting the car from neutral into first gear or from neutral to anygear for that matter. It just started a couple of days ago. It only happens after I first start it up. When it does happen, I have to turn the car off and move the shifter into first and then start the car. Any ideas from anyone? Or can anyone tell me if a worn clutch could be the cause of my problems?
Old Jul 6, 2006 | 11:31 AM
xxtavixx's Avatar
Sounds like you need to adjust your clevis slightly, or your synchros are losing their touch. Can you get it in if you double clutch?
Old Jul 6, 2006 | 02:53 PM
Vlasic's Avatar
-matt
Maybe Im thinking of it differently. Can you actually replace just the round rubber seal without pulling the whole thing out?
Old Jul 6, 2006 | 03:16 PM
nismology's Avatar
The PROPER method involves removing the pan.
CorollaULEV
30
Aug 9, 2021 08:11 PM
dinososexy2.6
Aug 31, 2015 05:37 AM
vanebecker
Aug 17, 2015 08:24 PM
