Too Much Oil
Old Jul 4, 2006 | 06:00 PM
cds166's Avatar
Too Much Oil
Just changed the oil in my 95 Max. I checked the dipstick and the oil level is about 1/2 an inch above the max line. Is this okay or should I drain some out?
Old Jul 4, 2006 | 06:09 PM
PLUMMAXSE's Avatar
Drain some out! When you overfill the engine, oil gets sucked into places that is should not go. Better to underfill than overfill!!
Old Jul 4, 2006 | 06:12 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
drain it out....some jack azz at an exxon one time put 4 quarts in my car when it only needed 1/4 of a quart lets just say the whole block was smoked out and most of that smoke was from the top of my head from being so pizzed. what im getting at is drain the oil you'll cause yourself a rebuild fast....
Old Jul 4, 2006 | 10:04 PM
Fr33way™'s Avatar
Wild for Width
It can stress the seals.
Old Jul 4, 2006 | 10:52 PM
nismology's Avatar
Underfill >>> overfill. Drain.
Old Jul 5, 2006 | 09:03 AM
RedfoxXx's Avatar
indeed, its caus alot of problems if you leav it overfilled, including many oil leaks and a verry unhappy vq30
Old Jul 5, 2006 | 09:58 AM
the_3d_man's Avatar
I shouldn't have to ask but you never know... did you turn the car off and let it sit for 10 minutes or so before checking? cause if not you will get readings like that with the correct amount of oil in there.
Old Jul 5, 2006 | 11:09 AM
Fr33way™'s Avatar
Wild for Width
You would think alot of lube places or the dealers would be regularly over-filling. Is there any way to really tell if the engine has been getting the proper amount over time? Would it just be leaks?
I ask because I'm just wondering the severity of the damage that can be caused. I'm sure this happens to Maxima's (and other cars) all the time.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
