Anyone with a Microvision 7000bct?
Old Jul 5, 2006 | 09:22 AM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
1. Does the Microvision 7000bct require the remote control to operate it?
2. How is this thing mounted behind the dash so it stays put?
3. Will I have to fabricate some kind of bracket?
Old Jul 5, 2006 | 09:49 AM
Gismo-T's Avatar
B!tch We Got a Problem
1.yes
2.mounting bracket
3.yes
I have one, but haven't installed it let , so I'm assuming that you need the bracket & remote.
Old Jul 5, 2006 | 09:52 AM
99NJMAX's Avatar
I've got one of those in my maxima. To mount it all you have to do is fit it in between the brackets that hold in your ac controls and radio and when you tighten the screws it'll hold the screen in place. I've only used the remote to change some of the display settings and wired a seperate switch to turn it on.
Old Jul 5, 2006 | 10:46 AM
semaj3708's Avatar
thanx Geo & 99njmax
Old Jul 5, 2006 | 11:59 AM
ManualMaxima's Avatar
5th Gen till she dies!
1. no
2. it held in place by squeezing it in between your radio brackets
3. no
Old Jul 6, 2006 | 07:54 PM
rteenie22's Avatar
does that guy on here still sell those i cant find the thread?
Old Jul 7, 2006 | 07:46 AM
rteenie22's Avatar
bump 4 answer
Old Jul 7, 2006 | 12:09 PM
Taken2DaMax's Avatar
Search for Redmax in the classified or group deal forums. He's the one that has been selling these things for a couple of years.
BTW The TV itself fits between the brackets with a little modification to the tv. The only thing that I did was cut off some of the plastic borders around the tv. The borders were in the way of the brackets, it made it harder for the tv to stay in place.
As for the remote, yes you need that to operate the tv. Make sure when you mount the tv in the dash, that the red sensor is visible. If not, then you won't be able to turn the tv on.
Old Jul 9, 2006 | 11:52 AM
rteenie22's Avatar
yeah but the thread isnt around anymore thanx anyway
Old Jul 9, 2006 | 12:39 PM
mendon99's Avatar
tastey wheat
?? not if you run the power through a switch, like i did. the remote isn't nessecary at all unless you want to change aspect ratios and such. hell, i haven't even touched the remote that came with mine. its still in the box.
no need for mounting bracket either, it wedges in behind there just fine. that and i got creative with some zip-ties, and it stays put.
Old Jul 10, 2006 | 04:09 AM
semaj3708's Avatar
I've did that yesterday. It works fine, however now I'm getting feed back wht the tv is off. I wired the negative to a switch, the red and orange wire are going to acc on power. Should I seperate the two?
Old Jul 11, 2006 | 04:05 AM
mendon99's Avatar
tastey wheat
the power should be just running to a power line (like tap your HU's power or remote, whichever), they shouldnt be together... the switch line should run to the power on the tv.
if you still get feedback, ground the negitive. it really should be just grounded anyways... thats prolly why you're getting feedback
Old Jul 11, 2006 | 04:33 AM
semaj3708's Avatar
That was the original problem the TV was on but not grounded, but I've fixed that with a new point, and have a switch on the negative. My question is the TV came with the red(I assume power) and orange(I assume turn-on) tied together. It was used, so no manual or remote. I'm alright with electronics, however some things just need to be spelled out. The TV is working no feedback, but I'm worried that it may be hooked-up incorrectly, and possibly short out.
Old Jul 11, 2006 | 04:54 AM
mendon99's Avatar
tastey wheat
the red a orange shouldn't be together if you're running it through a switch. the person that had it before you probably did not use a switch, so he tied the power and switch wire together, so that it would just come on with the head unit... its not nessicarily a bad thing to do, and probably won't cause problems, but if you're running it through a switch, they should be separate.
Redmax
Nov 16, 2006 01:18 PM
Redmax
Jan 23, 2004 09:54 PM
Redmax
Sep 29, 2003 08:04 AM
Redmax
Aug 21, 2003 09:27 AM
Redmax
Jul 22, 2003 05:15 PM
