exhaust leak = less power??
Old Jul 7, 2006 | 10:35 AM
WielkiWaac's Avatar
MaximaDriver
im just wondering i you can loose power because of leaking exhaust
Old Jul 7, 2006 | 10:57 AM
Kevlo911's Avatar
Kevlo for President
Yes depending on how close the leak is to the motor.
Old Jul 7, 2006 | 10:58 AM
Fr33way™'s Avatar
Wild for Width
I would think that a leak would cause turbulence which would slow the exhaust stream velocity. A leak before an O2 sensor could cause altered readings and screw with your a/f ration.
Old Jul 7, 2006 | 11:16 AM
bigpulve+'s Avatar
Yea if it was before the O2 sensor then it would read that there was more oxygen than there really is and would send more fuel into the engine making it choke more and run rich. After the O2 sensor it would have air coming in making the exhaust back up when it hits the air coming in and thus less exhaust exiting the tail inducing power loss.
Old Jul 7, 2006 | 11:58 AM
nismology's Avatar
You don't lose any open loop power since the ECU ignores the o2 sensors then anyway. You'll just lose power during light acceleration and your MPG while cruising will suffer dramatically.
Old Jul 7, 2006 | 12:04 PM
NmexMAX's Avatar
dot dot dot ...
It depends on how loose the exhaust flange is.
Old Jul 7, 2006 | 12:10 PM
bigpulve+'s Avatar
The ECu will not "ignore" the o2 sensors b/c that would be the same as not having any 02 sensors and my car didnt want to run when I forgot to put one back in when I was looking at my exhaust to make a lay out plan for putting my y-pipe I am getting in. O2 sensors control A/F ratios and make the car go. The ECU will not bi-pass them.
Old Jul 7, 2006 | 12:13 PM
NmexMAX's Avatar
dot dot dot ...
Do you know who you're trying to argue with?
nismology is a sick bastard, he sleeps with his FSM
nismology > you
Old Jul 7, 2006 | 12:16 PM
Mad_A's Avatar
Wow, didn't know that an exhaust leak could have such drastic effects on performance.. but now that I think of it I guess it makes sense
Old Jul 7, 2006 | 12:20 PM
NmexMAX's Avatar
dot dot dot ...
Open loop = WOT, WOT = Wide open throttle, wide open throttle = 'flooring it'
Old Jul 7, 2006 | 12:32 PM
gmax96's Avatar
son of a ***** i definetly need to change my Y pipe now after reading this thread and my cat back as well...
Old Jul 7, 2006 | 12:34 PM
NmexMAX's Avatar
dot dot dot ...
Make sure and read the thread properly including the red words.
Old Jul 7, 2006 | 01:03 PM
THT's Avatar
THT
Throbbing member
And your credibility just took a flying leap out the window...
Old Jul 7, 2006 | 01:04 PM
915Max's Avatar
There had to have been something else that was preventing your car from starting because I dont have one of the O2 sensors plugged in (Bank 1 sensor 2) and my car stills starts up and runs.... it runs a little rich though.
which reminds me... I have to get that fixed!!
Old Jul 7, 2006 | 03:13 PM
NmexMAX's Avatar
dot dot dot ...
On my A33B... only half of my O2's are connected.
Downward spiral.... {insert whistle}
Old Jul 7, 2006 | 03:19 PM
f550maranello2's Avatar
thats a load of crap.. ill explain it so everybody can understand... when u first turn ur car on in the morining for example the ecu will ignores values from the o2 sensors just untill the car gets warmed up..... same thing if u floor it the values are neglected...
Old Jul 7, 2006 | 03:22 PM
but to answer the original post... i have noticed that after i installed the ypipe i now have a leak somewhere.. and the car is a LOT slower than it used to be.... and the gas milage also suffered...
Old Jul 7, 2006 | 06:44 PM
WielkiWaac's Avatar
MaximaDriver
i have leak between b pipe and muffler and i feels like car is slower little bit
Old Jul 7, 2006 | 07:21 PM
gmax96's Avatar
i know this is a dumb Q? but could my cat. conv. be toasted since i have a leak on my flex pipe the one on my y pipe?
Old Jul 7, 2006 | 07:24 PM
96i30azn's Avatar
I heard an exhaust leak can also make your car faster ... from the guys at cartalk.
Old Jul 7, 2006 | 08:13 PM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
its cuz u need NAWWWWSSSS
i got bills, how bout i sell you a clue
Old Jul 11, 2006 | 04:55 AM
tarndt's Avatar
I had terrible pick-up (especially low RPM) until I fixed my exhaust problem. Got it fixed and the car feels brand new again! What a difference.
Old Jul 17, 2006 | 07:53 AM
99max78210's Avatar
My flex coupler blew on the stock y pipe. My engine sounded like crap and there was a significant power/mileage loss.
Old Jul 17, 2006 | 07:55 AM
nismology's Avatar
The question has been answered already. There is a power loss during light acceleration. WOT performance above 3000 RPM is unchanged.
lowpost99
Oct 26, 2025 06:53 PM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 7, 2015 07:26 AM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
