electrical problem( clear corner light)
Old Jul 7, 2006 | 05:25 PM
lee's Avatar
lee
after changing the clear corner lights on my car, my left side stopped working.
i checked the fuse and the bulb, both are good. also, my left indicator signal blinks faster than the right side. could someone help me fix the problem.
Old Jul 8, 2006 | 12:53 AM
MIXXMAX's Avatar
Make sure you have the correct bulb and see if the bulb is sitting correctly in the bulb holder. It seems like the bulb is not making contact, giving you a "burned out" indication.
Old Jul 8, 2006 | 09:54 PM
lee's Avatar
lee
the bulb is good, i even try the bulb on the right side.
Old Jul 8, 2006 | 10:40 PM
InfinitiJ30's Avatar
the wires that hook up to the plug that plugs into the headlight could have gotten loose..if all fails and u find out it wasnt a wire, just run a wire from the battery to the negative terminal of ur battery and your problem will be fixed
Old Jul 8, 2006 | 11:26 PM
bunna203's Avatar
if you have a test light see if you're getting power and ground. your power might be grounding out or something
JMag90
Aug 25, 2015 09:17 AM
Maxboy23
Aug 21, 2015 11:02 AM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
