Cruise Control Half Moon Loose
Not normal.
Check for a loose nut somewhere. There are two nuts on either side of a threaded "screw" that adjust the cable's positition. Check that the threaded screw that houses the cable is secured between these two nuts. Tighten if necessary.
Originally Posted by cam_honestiam
Not normal.
There is a nut that should keep that piece tight. Other than that, there is no other contact with the throttle. If the nut is gone, find a replacement and use loc-tite on the threads. That would be the only reason for a loose piece...??? Perhaps you should check (if the nut IS there) for proper tightening.
Has anyone else had this problem?
tseng1023
Oct 15, 2015 08:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
