Short Shifter Help
Old Jul 9, 2006 | 08:16 PM
Da_Shatterer's Avatar
Short Shifter Help
I've been looking into the mods that can be put into my Maxima and I think the short shifter is a worthwhile investment. Anybody have any experiences with them and can recommend some good brands? Also, about how much does a good, decent short shifter run? I've seen them ranging anywhere from $30 (Ebay crap) to over $200. What's the best short shifter I can buy value wise without spending an arm and a leg on it? Thanks.
Old Jul 10, 2006 | 12:44 AM
maxima_kid's Avatar
B&M or TWM shifters. Both would run around $130ish
Old Jul 10, 2006 | 04:56 AM
Chickan's Avatar
I bought the pacesetter one IIRC, for ~$85 on ebay. Make sure you get one that is adjustable, and one that actually lowers the stock shifter. Having a short throw is fun, but lowering the shifter to get it out of the way of your cd player is crucial.
On a side note, I don't particularly recommend it, as to make it fit, I had to lower it all the way down, so the throw is MUCH too short. Even at that, it is all the way to the front, and touches the plastic trim piece, kind of annoying.
Old Jul 10, 2006 | 11:11 AM
NAPhi_Shift's Avatar
i have b&m in my car. as with any short shifter, the throws are significantly shorter, albeit a little bit "notchier" than stock. i also like that its not too high up, i like the shifter a little lower than stock.
you gotta pay to play. good luck!
im leaving the 4th gen world soon, well technically i already left it since i have a new car but its still for sale.
Old Jul 10, 2006 | 11:14 AM
i30ds's Avatar
Armed and Dangerous
B&M... Best STS out there.
Old Jul 10, 2006 | 01:56 PM
Apparition's Avatar
Ichiban King
yeah B&M FTW, you wont have any problems after its installed.
Old Jul 10, 2006 | 02:24 PM
i30ds's Avatar
Armed and Dangerous
Yup.
A little while after I installed it, I started getting a rattling in 5th gear. I was p!ssed. After a few more thousand miles it kept getting worse and in other gears too. I thought it was the B&M but it turned out one of the bolts that holds the shift rod to the tranny was slowly coming loose. Eventually, the nut cam off and the bolt became dislodged and the shift rod separated from the tranny. The car was stuck it gear!!! I had to pull over an call a tow truck. I put new bolts in with lock washers and lock nuts on the shift rod and the rattling was gone.
I wrongfully blamed B&M.
Old Jul 11, 2006 | 06:45 AM
nismos14's Avatar
§è~® f®ÈÄk
SRE is the best by far, cheapest, solid construction - made from steel, no issues with the shifter sitting to close to the front gears after install like other people have had with the b & m. It's like $23 shipped.
Old Jul 11, 2006 | 02:34 PM
Where can I find this shifter?
Old Jul 11, 2006 | 02:42 PM
nismos14's Avatar
§è~® f®ÈÄk
Ebay, but no longer available.
Old Jul 11, 2006 | 02:58 PM
Is this short shifter any good?
Old Jul 11, 2006 | 07:38 PM
ManualMaxima's Avatar
5th Gen till she dies!
that is the one i have. i like it. But think it needs to be more sloid feeling, but it has been good, no problems. i would reccommend it, but i bet the b&m is better.
Old Jul 12, 2006 | 05:34 AM
Flava_24/7's Avatar
Boosted Panda
The B&M shifter is the best built shifter out.
All the others are just as functional but dont have the quality the B&M unit does, so its up to you how much you wish to spend.
Personally, I bought the 20$ OBX one off ebay, It is SS and not the aluminum and Ive had it on for well over 3 yrs and no issues. The STS just shortens throws, not height so if you want that short shifter look you will hve to hack it, many have including myself.
i30ds,
I had the same thing happen to me, although it never rattled before it came off...
http://forums.maxima.org/showthread....ht=fun+shifter
Old Jul 12, 2006 | 08:26 AM
Chickan's Avatar
Is the SRE one adjustable? For that price it sounds like it is not. Also, does it lower height at all? Or just throw? Personally, the stock throw didn't bother me, it was just height. I probably should have chopped my stock shifter.
Old Jul 12, 2006 | 09:03 AM
i30ds's Avatar
Armed and Dangerous
i30ds,
You too huh? I thought for sure I would be the only one to have this happen to. It really sucks. I had to call a tow truck because I was stuck in 4th gear (happened on the 4-5 shift). As soon as I went to shift, the shifter had a **** load of free play and the whole shift rod crashed down on the heat shield over the cat. I instantly knew what had happened. I slowed down and pulled into a chruch parking lot and looked under the car and saw the shift rod hanging down.
Old Jul 12, 2006 | 09:08 AM
Flava_24/7's Avatar
Boosted Panda
. I looked under the car and saw the shift rod hanging down.
So you dont have the heat sheild in place?
Old Jul 12, 2006 | 09:13 AM
abci30's Avatar
oh noes!!!!1111
^^^ Same thing happened with mine but i was able to tighten it and get new bolts before anything like that happened.
Oh BTW get the B&M. i like it a lot
Old Jul 12, 2006 | 09:22 AM
i30ds's Avatar
Armed and Dangerous
I still have the heat shield. The rod separated from the tranny not the shifter like what happened to you. So it was the other end of the rod hanging down. The effect is still the same though. No shifting. All I had to do for the fix was jack up the car put the rod back into the tranny shift fork and install a bolt with a lock washer on one end and a lock nut on the other.
Old Jul 12, 2006 | 09:25 AM
i30ds's Avatar
Armed and Dangerous
Good thing you got to it. I just thought the rattling was from the B&M shifter. It kept getting worse and worse because that bolt was getting more and more lose with each day.
Old Jul 12, 2006 | 11:47 AM
Apparition's Avatar
Ichiban King
i30ds,
How did you go about hacking it Flava? I was laways thinking that the STS didn't lower the rod height and you confirmed my suspicions..
Old Jul 12, 2006 | 11:56 AM
Flava_24/7's Avatar
Boosted Panda
I used a Dremel tool.
Old Jul 17, 2006 | 07:50 AM
99max78210's Avatar
I put one of the cheap short throw shifters. I've had no problems with mine. I guess I got lucky.
Old Jul 17, 2006 | 08:18 AM
86maxima96's Avatar
I Broke OT
and then rethread it?
Old Jul 17, 2006 | 08:36 AM
Flava_24/7's Avatar
Boosted Panda
Nope, had to use a universal type of shift ****, that clamps onto the shifter versus threading onto it.
In order to get a threaded **** onto it, you would have to take some of the diameter off, and then have it threaded. Since the shifter was shortened, its quite a bit thicker down low then the top section is.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
atriuum
Sep 28, 2015 01:19 PM
