Transmission Replacement?
Old Jul 12, 2006 | 06:10 PM
PlayHard's Avatar
I take my 97 SE into AAMCO because I notice the tranny fluid looks burnt thinking I need a flush (after reading tons of posts here I see no flush is a good flush). I also have problems that for some reason my AT won't shift into 2nd gear. Goes from 1 to 3. Also OD slips and can't be used
Recommendation: Rebuild Tranny. Cost $2325. I don't even have that much in this car
I didn't have any problem until I replaced the engine. Is there any way to tell if the engine and tranny came from the same car? Serial# or anything? I think they gave me a bad tranny off a wreck when they swapped my blown engine for a used one. Would it be easier for someone to change them out as a whole assembly?
Thanks.
Old Jul 12, 2006 | 06:14 PM
NmexMAX's Avatar
dot dot dot ...
car-part has them for cheaper, but I'm not sure I'd take tht option on a transmission (auto) go somewhere else because that's robbery.
Old Jul 12, 2006 | 07:01 PM
grandmastr's Avatar
I seen trannies as low as 300 bucks at junk yards.
Old Jul 12, 2006 | 07:31 PM
f550maranello2's Avatar
yea ur getting if u pay that much.. i got a trans with 9k miles for 500 bucks
Old Jul 12, 2006 | 08:06 PM
easter9053's Avatar
Just get the tranny replaced with a used one. I did 3 years ago on my 95 5speed. No problems since.
Old Jul 13, 2006 | 11:10 AM
PlayHard's Avatar
Ok, Thanks. I understand I can get a used tranny much cheaper.
Does anyone have any idea if there are any numbers on the tranny case that correspond with the VIN or anything on the car? I'm going to try and make my case that the shop that changed my engine may have swapped to a bad tranny out of the car they took the engine from.
Old Jul 17, 2006 | 09:51 AM
PlayHard's Avatar
What about replacing the AT with a 5 speed. Can someone point me to how to make this happen? There is probably a link on this site.
Old Jul 17, 2006 | 10:03 AM
NmexMAX's Avatar
dot dot dot ...
Read the STICKIES
Old Jul 17, 2006 | 10:33 AM
PlayHard's Avatar
I think the link is bad:
Can I convert a automatic to a 5-speed?
Yes.
Warning: This is not a weekend project! This involves time and money and someone who knows what they are doing!
http://www.fastmaxima.com/5spd_conversion.htm
Anyone else have any info on Tranny changeouts from the questions above? The 5 speed would be nice but sounds expensive and time consuming. I'm looking to find out if there is any way to prove a mated engine/tranny????
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
PH98I30
Aug 20, 2015 04:25 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
