replacing door inserts?
Old Jul 17, 2006 | 07:00 AM
wetzelman1's Avatar
Do you have to take the entire door panel off to replace the insert or is there an easier way?
Old Jul 17, 2006 | 07:13 AM
Flava_24/7's Avatar
Boosted Panda
Door panel will have to come off, if your actually replacing the door inserts. If you doing an overlay then it wouldnt be necassary.
What are you replacing? Cloth for leather?
If so, its not going to be a direct swap.
Old Jul 17, 2006 | 08:37 AM
wetzelman1's Avatar
I actually just bought some vinyl and I'm going to take the cloth inserts out and fit the new vinyl too them.
I just did a semi-custom leather swap.
Old Jul 17, 2006 | 09:07 AM
Flava_24/7's Avatar
Boosted Panda
Well, thats not going to work.
With the cloth setup, you cannot remove the "insert" The cloth is attached to foam which is glued to the door panel. The leather versions are actual inserts that have tabs that insert into the door panel and secure by folding them back.
Your best bet is going to be to lay the Vinyl on top of the cloth.
Old Jul 17, 2006 | 09:50 AM
Chickan's Avatar
yeah, I tried to do this too, and I gave up and just put the cloth back on (badly at that). Probably not worth it IMO.
Old Jul 17, 2006 | 10:39 AM
wetzelman1's Avatar
I'm going to give it a go with just using spray adhesive and cutting the vinyl very precisely. I allready experimented with tucking it in around the edges, so I think it should come out allright. I'll make sure to post pics of the final product. Thanks for the help guys.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
delerium75
Aug 19, 2015 11:08 AM
