I got one more lighting question for ya'll, my dome light does not work correctly
Old Jul 13, 2006 | 05:57 PM
ManualMaxima's Avatar
5th Gen till she dies!
Well my dome light it not working right. It does not come on when you open the door. If i flip it to the on postion, it comes on no problem. BUt whne flipped to the postion where it is suppose to come when the door opens, it does not do so. What could this be. Thank you guys
i am trying to get all the kinks in my car worked out
Old Jul 13, 2006 | 06:25 PM
RedfoxXx's Avatar
bad door switch? something to take a OHM meter to each one, just a thought if someone has been slamming thos doors really hard
Old Jul 13, 2006 | 08:57 PM
Black Maxima
Does your key ring light light up when you open the door?
Old Jul 13, 2006 | 11:08 PM
you know i have not checked or noticed if it does or not, but i just went outside and it does not light up when i open the door
Old Jul 14, 2006 | 09:08 AM
Black Maxima
I think you fried your BCM in your dashboard behind the CD Player. I had the same problem with the dome light and key ring light. Try replacing the bulb in the key ring to verify first.
Old Jul 14, 2006 | 09:33 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Check your door switches. I had one got bad. $10 later it was working again. Easy fix.
Old Jul 14, 2006 | 01:57 PM
it is a pretty new led in the key ring.......it is not the door switches cause i just replaced one, and both door lights are working. i bet it is that bcm.....gotta see if i can junkyard one.
Old Jul 14, 2006 | 06:50 PM
Black Maxima
I bought mine from someone on here for $25 shipped. Keep in mind it's a $900 dealer part. But if your key ring light is new, it has to be your BCM. I fawked mine up when I crossed the positive and negative of the key ring light. Brought it to the dealer, they told me it was the BCM.
Old Jul 14, 2006 | 07:20 PM
RedfoxXx's Avatar
just wondering what dose BCM stand for, what dos it all do
Old Jul 14, 2006 | 07:25 PM
Black Maxima
Body Control Module. There are many located in your car. It's basically any black box with a bunch of electronic pieces and switches in it that control areas of the car. The one that ManualMaxima needs replaced is behind the CD player.
thanks a guys, i can g to the junk yard and pick one up for $5, like everything eles i pick up.....it i snot that big of a problem for me, but i would rather it work correctly
carguy96
20
Feb 6, 2021 06:21 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
spidgeon
Aug 18, 2015 05:46 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
