Car won't start - weird issue (Pls HELP)
Old Jul 14, 2006 | 05:20 AM
BourneJ's Avatar
Hello All,
I drove around running errands for most of the day. Came home & just tried to start the car to go to work.
Nothing happens when I turn the key.
Battery is good, fuses are good, all the controls on the dash light up, everything is normal until I try to start the car. It doesn't try to turn, NOTHING. I tried moving the gears from P to N (sometimes it happened like this & that helped), but not this time.
Any ideas?
- Jay
Old Jul 14, 2006 | 05:32 AM
WielkiWaac's Avatar
MaximaDriver
damn Slawek!!
it doesnt sound good
Old Jul 14, 2006 | 05:51 AM
Papa Squat's Avatar
replace starter
Old Jul 14, 2006 | 05:53 AM
motocross416's Avatar
I had a problem like that, it ended up being one of the fusible links near the battery, pull that fuse box cover and make sure all of those are good.
Try wiggling the key when you turn it to on, your ignition switch may be on its way out too.
Old Jul 14, 2006 | 05:58 AM
NAPhi_Shift's Avatar
your starter could be completely shott... remove it, buy the brushes and just replace the brushes in the starter and you should be good as new.
Old Jul 14, 2006 | 06:16 AM
99grnmaxgxe's Avatar
So no cranking at all? What year do you have? How many miles?
Old Jul 14, 2006 | 06:36 AM
WielkiWaac's Avatar
MaximaDriver
its 97 or 98 i dont remember what he has
Old Jul 14, 2006 | 06:39 AM
BourneJ's Avatar
It's a 98 with 79K
I'm suspecting it might be the starter. For the past 5-6 days, the car struggled to start, sometimes it needed a few tries.
I wonder how much they're going to charge me this time (I live in Eastern Europe and I swear everything's 200% more expensive than it is in the states)
Old Jul 14, 2006 | 06:59 AM
WielkiWaac's Avatar
MaximaDriver
try to rebuild it.
buy new brushes. (hey should be cheap in poland). that should help
Old Jul 14, 2006 | 09:28 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Starters are very easy to change yourself. See the writeup on motorvate.ca
Old Jul 14, 2006 | 09:31 AM
IlyaK's Avatar
The Golden One
Man...I hope you fix it but I just wanted to say that I wish I lived in Poland (I'm ukrainian born - lived there until I moved here at 3). I would love to have a Max somewhat modded and be able to take it to the German Autobahns. Or through some of the Ukrainian/Polish country. That would be so nice...anyway...like everyone else...try the starter. I had the same problem, but it was a combination of the starter, crankshaft sensor, and fuel pump. Mine started out somewhat sluggish and then got worse aswell.
Old Jul 14, 2006 | 10:57 AM
friscomob's Avatar
try hitting the starte with like a stick and the car should crank maybe even start i did that to my car and it started up perfectly every time after that!!!! let me know
Old Jul 14, 2006 | 01:15 PM
BourneJ's Avatar
Yes, it's quite fun to drive around a car that you rarely see on the roads here. I've only seen 2 other maximas (US Spec) and both were driven by older dudes, no mods.
Yes, I hit it with a hammer & it started up
Now I know it's the starter.
Thanks for all the help everyone.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
Jcof88
Aug 3, 2015 10:43 PM
