Headlight Install???
Old Jul 15, 2006 | 07:49 PM
th0ught's Avatar
Damn I've had a new set of headlights and clear corners sitting in my garage for the past month or so. I finally decided to install them, only to run into the difficulty of removing the two nuts next to the radiator (located behind the headlights). (Pictured here: http://www.vqpower.com/images/clrlights/PICT0219.jpg) I've tried every angle I could think of with various tools for the past few days with no luck, any tips or suggested tools to finally install these?
Old Jul 15, 2006 | 08:32 PM
Mxrider52's Avatar
I support for what?
Small ratchet 1/4" with small extension and the socket
That what worked for me
Old Jul 15, 2006 | 08:55 PM
Fre$h_TurK
i need to change my back stop light...where do i start to look first
Fre$h_TurK
Old Jul 15, 2006 | 09:47 PM
Cdg2125's Avatar
Small rachet with the right head. Use the small rachet with the handle faced towards the ground (not up toward you). It should be able to move enough to loosen the nuts to take off with you're fingers. Thats the only way I got them out.
Really? If you mean your break lights....open the trunk, pull out the tabs for the trunk lining near the light, pull the bulbs and replace. That simple
Old Jul 16, 2006 | 08:12 PM
bklynzsleepy's Avatar
Get a ratchet and a 3" extension. That's what I have and it works perfectly.
MaxLife17
Jun 27, 2019 01:37 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
