Cruise Control 96 SE
Old Jul 17, 2006 | 09:21 AM
packerZ's Avatar
I was on the interstate this weekend and tried to use my cruise control (it always worked before). The main switch on lower dash shows engagement (green light) but no engagement lights on instruments before or after stalk "resume" button engaged ("cancel" and "resume" and main control tried several times...no cruise control!! I could not find a fuse in the interior fuse box or engine bay fusible boxes marked for cruise control. Am I looking right at it and not seeing it?? I think that's all that's wrong/or at least where I need to start but "where it be at" Please direct my tired Ole eyes, Thanks!!
edit: 07/17/06 1615. See Cardanza's post/thread above
Old Jul 17, 2006 | 12:37 PM
IlyaK's Avatar
The Golden One
The fuse in the engine bay for the cruise control is labeled ASCD...it's located in the fuse box infront of the battery I believe. Also...read this link...your problem might actually be a bad speedometer head...
http://forums.maxima.org/showthread.php?t=432698&page=2 (page 2)
Old Jul 17, 2006 | 12:50 PM
packerZ's Avatar
Thank You!! I'll check "ASCD" fuse tonight! I really can't believe that speedo head has to changed automatically if cruise control doesn't engage...maybe an issue if gauge cluster/speedo component changed or extremely high mileage but not at 106K. Again, thanks and I will check, (also check throttle wire/hose connections) post back if that's not it. Doug
Old Jul 17, 2006 | 01:34 PM
RA030726's Avatar
I'm nutty for Nissans
Does your horn work? If not your problem would be the clock spring.
Old Jul 17, 2006 | 05:18 PM
Brent_Cunniff's Avatar
I've had problems lately with mine, I'll check the fuse.
Old Jul 17, 2006 | 05:20 PM
romerocnj's Avatar
dont mean to post jack but i was just at the store buying fuzes and i bought these really cool ones that light up when they blow. it makes finding blown fuzes a lot easier
Old Jul 17, 2006 | 06:04 PM
fro98665's Avatar
Is it throwing any codes?
Old Jul 18, 2006 | 06:18 AM
packerZ's Avatar
No codes, horn works, no blown fuses, all connections at vacuum unit, all cables operate properly and brake lights work(switch operates)... but no Cruise Control. I think I'll try to test continuity for fusible "ASCD" link beside battery and at "resume/set/cancel/accel" unit for the steering wheel. This is wierd!! From the postings; I guess I am NOT alone!!!
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
