Amp Fuse and Ground ?
Old Jun 22, 2001 | 05:12 AM
tomj's Avatar
I just did a complete install of Blaupunkt head unit and in-dash changer, Pioneer speakers all around and a Mobile authority Amp. Problem is the inline fuse right after the battery blew after a week of use. Now if I put a new fuse in it blows immediately. I checked all my connections and wires and made sure there was no short anywhere. I'm thinking I might not be getting a good ground. The amp is under the passenger seat and is grounded directly to the metal floorboards. Is there a better place to attach the ground wire? Also, does anyone know if I'm using the right size fuse. I am using a 30 Amp because the head unit is 25x4 RMS and 40x4 Peak and the amp is 40x4 RMS and 75x4 Peak. That adds upto 260 RMS and 460 Peak. I figured 30 would be safe. Thanks for any help in advance.
Old Jun 22, 2001 | 06:28 AM
Daniel B. Martin's Avatar
Originally posted by tomj
... I'm thinking I might not be getting a good ground. ...
A fuse blows when the current drawn through it exceeds the fuse rating. This results from a short circuit or a load device with an excessive power demand.
A bad ground results in an open circuit. The load device will not work. The fuse will not blow.
Old Jun 22, 2001 | 06:41 AM
tomj's Avatar
Ok, so you don't think it's the ground connection. That makes sense since it was working for a week and I didn't change anything. So I must have a short somewhere that I haven't found yet or there is a problem with the amp.?
Old Jun 22, 2001 | 06:45 AM
... So I must have a short somewhere that I haven't found yet or there is a problem with the amp.?
Yes.
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
