Timing chain noise (New Question)
I asked everyone awhile ago about noise coming from a cold engine in a 95 Maxima. I was told it was the chain tensioners, Technical service bulletin NTB96086. I talked to two dealers, One said the bulletin was for a 94 Max and that replacing the chain might require me to covert to a belt system as part for the chain system are no longer available. The second dealer said he never heard of the problem and it would cost me over $1000.00 to replace the chain and misc. parts. Can anyone tell me what parts I need and approx. price I should expect for install? I'm capable of doing this myself but according to the shop manual it looks like alot of work. Any information would be greatly appreciated.
I missed your last post
I had a similar (wrong) diagnosis of my 96 Maxima. Started as a knocking when the car was idling, but only after it had been running for about 2 minutes. I took the car to a Nissan Dealer and was told my timing chains were losing tension. I was told the tensioners, gears and the chains all needed to be replaced for a grand total of $2700. My brother-in-law (who is ford tech) told me of a similar problem they had with the Rangers. Said they solved the problem by draining a quart of oil and adding a quart of transmission fluid and driving the car for about an hour (then drain all oil and replace). I did this, and after driving about 45 miles, all noise ended. Almost 5,000 miles later my car is still purring like a kitten! (It may not be your problem, but it is a lot easier and alot cheaper!)
Originally posted by par1969
... One said the bulletin was for a 94 Max and that replacing the chain might require me to covert to a belt system as part for the chain system are no longer available. ...
... The second dealer said he never heard of the problem ...
The National Highway Traffic Safety Administration maintains online databases of recalls and Technical Service Bulletins. Go to
http://www.nhtsa.dot.gov/cars/problems/
You will find this:
Service Bulletin Number: NTB96086
Bulletin Sequence Number: 61
Date of Bulletin: 9609
NHTSA Item Number: SB049475
Make: NISSAN
Model: MAXIMA
Year: 1995
Component: ENGINE:TIMING GEAR AND CHAIN
Summary: ENGINE TIMING CHAIN NOISE. *TT
Unfortunately, the TSBs are only in summary form. To get the full text you have to use a for-fee service such as AllData. For more information visit your local friendly honest and competent Nissan dealer or call 1-800-NISSAN1.
... Can anyone tell me what parts I need and approx. price I should expect for install? I'm capable of doing this myself but according to the shop manual it looks like alot of work. ...
Look at the timing chain cover of your engine. It is aluminum and a dull silvery color. Look at the area just rearward of the engine mount and you will see a stamped steel metal plate fastened to the timing chain cover with four bolts. This is the timing chain tensioner cover. Remove that cover to gain access to the tensioner. Remove the tensioner. Probe the oil supply hole which is now exposed to verify that it is clear. Decide whether the tensioner should be replaced, or only cleaned. Install the new or cleaned tensioner. Install the cover.
Starrider
09-17-2015 07:26 AM
MaximaDrvr
08-19-2015 08:20 PM
