ecu code woes
Old Jul 19, 2006 | 08:00 AM
RicoSuave98's Avatar
ecu code woes
so i keep pulling codes that seem to have no apparent meaning. 0312 and 0413 to name the most recent. are these just garbage nothing codes or is the decoder defective, because i can't even put the codes in it to diagnose.
i also pulled a 0704 which is the evap control system pressure sensor, how the hell do i fix that? just replace it? is it expensive?
thanks for any info you have to offer
Old Jul 19, 2006 | 02:44 PM
glenmoormax's Avatar
10 psi
mess with your sensors make sure all are connected, try pulling your codes off your ecu using the CEL flashes instead of the OBD2 if you want to make sure, or give me or Justin a call, we'll come help you. Only for another bad *** beef quesidillllla
Old Jul 19, 2006 | 04:18 PM
i'll def check the sensors, so i don't know. i have so much **** wrong im thinkin about just takin it in
Old Jul 29, 2006 | 03:36 PM
kmiller's Avatar
My car's throwing out 0102, 0304, and 0707. Hopefully when I get in from work tonight, I can read up on what these codes mean.
Old Jul 30, 2006 | 02:23 AM
Sy0p's Avatar
my car throws codes and codes and more codes. i have the woes too.
Old Jul 30, 2006 | 03:56 PM
TunerMaxima3000's Avatar
If you want the info on the codes I have the Dealers CD manual, also the stickies list every code.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
