Having 2 problems, I NEED HELP!
Old Jul 25, 2006 | 06:10 PM
Scooobay's Avatar
Ok, i installed a microvision 7 inch screen, install went fine, i even un-did my head unit and rewired everything ( Twice ) and the screen works fine. But when i have my ps2 plugged in i hear no noise but when i turn the ps2 on i hear a " weeeeeeeeeeen "-ing noise. I made sure the RCA's arent near a power source, tried 6 different grounds, i even cut open my inverter and wired it directly to the battery. anything i try im still hearing this weeening noise. wierd thing is, i dont hear it when the car is off, my dvd's and games play fine and no noise, but as soon as i start the car up i hear it.
Other problem is i have a 5speed, and my shifting after running at the track this past friday has been " Rubbery" . Like it's wierd cuz it's only my top shifts " 1st , 3rd , 5th " are hard to get into but all the bottom shift's, 2nd, 4th, reverse engage perfectly. I dont know whether it's my shifter busing, or somethign going on with my clutch, or whatever the issue, all i knoiw is i need HeLp!.
Old Jul 25, 2006 | 06:29 PM
rob15job47's Avatar
Well i dont know anything about tranny's but im thinking its alternator noise your hearing. But in all you might get a ground loop isolator it is supposed to reduce humming, engine, and alternator noise. Radioshack sells them for 17 bucks.(cat no.270-054) I work there so I know they have them. Probably can get a better one somewhere else though.post that question in the audio section and they will have it figured out fast im sure!
Old Jul 26, 2006 | 06:09 AM
Scooobay's Avatar
yea i found out about the 2nd problem but anyone have an ide aabout teh shifting?
Old Jul 26, 2006 | 08:13 AM
xlr8r's Avatar
stoopid answer I know, but have you got enough oil in the tranny?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
