Question to all HID guys
Old Jul 25, 2006 | 06:46 PM
black97's Avatar
I'm going to buy HID kit but i think it will create a small issue, in Canada there is always running lights (hi beam small voltage) so i think i'll lose that with HID. Unfortunately i don't have a fog lights witch i could've rewired to make them work like a running lights. I sure can turn my HID on when i'm driving the car but i don't really want to burn my kit when it's not neccesary.
So guys what can i do about that?
Anyone had the same problem?
Old Jul 25, 2006 | 07:10 PM
bkmax96's Avatar
wire em to the low beam
Old Jul 25, 2006 | 07:29 PM
Tatanko's Avatar
Bacon Lover
I really wouldn't attempt to wire up your true DRL's (lower power) with the HID's, could create issues. I personally wouldn't want my headlights on all the time, either, you'll kill the bulbs much quicker.
Old Jul 27, 2006 | 01:20 AM
aznxenon's Avatar
Yeah, can't you just block off the wire to trigger the high beam?
Old Jul 27, 2006 | 03:03 AM
Zero-K's Avatar
VQ30DET
If you run your DRL with HID, you will probably end up with quite a few headaches.
To avoid this with my HID kit, I ended up cutting off my DRL. (to see how to do this --> http://forums.maxima.org/showthread.php?t=150955 )
Now for when my car goes in for inspection, They would give me a hard time for no DRL, so I wired up a switch that is connected to a relay that kicks them on when my key is "on". So I leave the switch off and don't have DRL's, but when I take it in, I just hit the switch and they dont' say anything because it's a light in the front of the car that automatically comes on when the car is running.
Hope that helps.
Old Jul 27, 2006 | 04:21 AM
bohead's Avatar
Interesting, I'm from Canada and I don't have DRL on my 99 Maxima. When I went in for inspection, they said nothing about the DRl too. Just disconnect for DRL like mentioned above, or go all the way and get bi-xenon projectors and do the retrofit.
FlaMark
25
Aug 28, 2015 10:15 AM
KristyKarina
Aug 23, 2015 09:53 AM
maxipower
Aug 21, 2015 11:10 AM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
doobadoo
Aug 15, 2015 06:43 PM
