Very hard shift, Somethings it takes a 2nd time to shift
Old Jul 26, 2006 | 03:50 AM
JEXTEL's Avatar
I checked my ATF yestaday and it looks like its over filled/reddish color and doesnt smell brunt...But my tranny has a very hard(well not exactly a hard time just the rpms shoot up and rev longer than they should then shift fine) time shifting into 3rd(45mph)Shifts fine here and there So my question is the problem is prolly with the tranny itself? Can it be electric? Also do Overdrive have to do with anything?
Old Jul 26, 2006 | 04:03 AM
njmaxseltd's Avatar
Could just be sticky soloniods. Pull the solonoid & valve body down and clean it up. Check the screen on the pump, clean out the pan magnets, reinstall everything and fill it up with fresh fluid.
Old Jul 26, 2006 | 04:10 AM
JEXTEL's Avatar
Thanks do you think the avg. DIY can do that? And also there's no codes coming up...
Old Jul 26, 2006 | 11:44 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
yea thats a pretty simple job
Old Jul 26, 2006 | 12:24 PM
95mtlMAXSE's Avatar
shift_Puff
yeah, take out the oil pan and the solonoids should just pull out. I would even change them, but that's just me
Old Jul 26, 2006 | 12:28 PM
scubasteve's Avatar
the transmission oil pan =]
Old Jul 26, 2006 | 12:55 PM
JEXTEL's Avatar
Originally Posted by bill99gxe
Here's what you need:
==* Tranny Pan Gasket 31397-80X01 (required if dropping the pan)
==* 19mm Tranny Drain Plug 31377-31X06 (optional, but might as well)
==* (21) Tranny Pan Bolts 31377-32X02 (required if dropping the pan)
==* Tranny "Screen" inside transmission (some think it is a filter, but it is not. Changing isn't necessary, but while you have the pan off, you might as well consider replacing) 31728-80X04
Thats what i need, I found that on another topic?
What do i use to clean them?/How much would it cost to replace them?
Also would Auto-RX or Trans-X create more problems or stop the problems?
Old Jul 28, 2006 | 11:18 AM
JEXTEL's Avatar
Or this I know this doesnt apply to the maxima but it basically what i need to do correct?
REMOVE DAIN PLUG AND DRAIN ATF
REMOVE OIL PAN (19 Bolts)
EXAMINE PARTICLES IN PAN - Remove the magnets and use them to collect steel particles.
REMOVE OIL STRAINER - Separate the solenoid wire, Remove the 4 bolts, oil strainer and 3 gaskets. Clean Strainer
INSTALL OIL STRAINER - Install 3 new gaskets. Install the oil strainer with the 4 bolts. Clamp solenoid wire.
INSTALL OIL PAN - Install the 4 magnets in the indications of the oil pan. Apply FIPG to the oil pan. Install the 19 bolts and oil pan.
FILL AND CHECK ATF
MaximaRaj
27
Oct 2, 2015 07:31 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Trin1j23
Aug 12, 2015 08:31 PM
