Help Needed...Vehicle Speed Sensor location
Just as the title says...Just needing a pic or very good instructions on finding the vehicle speed sensor.
I don't have my Haynes here at work so I can't just flip over to the correct page.
-Jeff
-Jeff
i just replaved it on my brother's 97 last weekend. if you look from the top by the throttle body, you will see a white cable goint to the top of the diff - its the harness. the sensor is held in place by one 10mm bolt, and is easily unscrewed from the bottom the space is limited there for a wrench, so be creative, unless you have all kinds of tools.after you unscrew the bolt, you can rotate the sensor to the right, and then pop it with a screwdriver againts the ear which held the bolt. it may be a little stubborn, because it has an o-ring or two. the hardest part for me was undoing the harness (i HATE those connectors!!!). after that the reinstall is a piece of cake.
oh yeah, it cost me about $40 from the dealership (with the shop's discount)
mrc00l88
01-25-2024 01:14 PM
95Maxi
09-02-2015 08:49 PM
