Front caliper pin bolts...
Old Aug 2, 2006 | 07:44 AM
d00df00d's Avatar
Old enuf to pick his own gears
Just dropping a note here, in case anyone cares:
DO NOT OVER-TORQUE THESE BOLTS. According to the FSM, the torque spec is 22-31 lb-ft, which is plenty. I snapped one of mine yesterday and nearly snapped the other three with 40-45 lb-ft, which I was using because I was somehow far too awesome to check the FSM first.
I replaced the broken/breaking ones with M8 1.0 20mm bolts from AutoZone.
Old Aug 2, 2006 | 07:57 AM
Bassman607's Avatar
Are you talking about the caliper mounting bolts? One part of the caliper slides on pins that you lube.
Old Aug 2, 2006 | 08:56 AM
d00df00d's Avatar
I'm talking about the bolts that go through caliper into the sliding pins.
Old Aug 2, 2006 | 09:58 AM
nismology's Avatar
I haven't used a torque wrench on those and i've never stripped/snapped em.
Old Aug 2, 2006 | 10:16 AM
xxtavixx's Avatar
Well, I appreciate your honsety haha. I am planning to go through my brakes this weekend, I'll make sure not to over tighten them. But if I do, I know the bolt size
Old Aug 2, 2006 | 10:45 AM
mindlessoath's Avatar
i never had used a torque rench before, but then one day i found out they were seized in there - and couldnt remove them. so i had to get all new hardware. then i torqued them to spec, but even then, i would say i didnt need too. just dont be to hot with the wrench and dont do what so many un experianced people do (over tighten parts that dont need to be).
Old Aug 2, 2006 | 12:58 PM
MIXXMAX's Avatar
Yeah, those bolts are real soft and the small amount of stress put on them will make them snap and break. I broke one while trying to loosen while I was changing my rear pads last week. I have a torque wrench, and I tightened them almost 10 ft-lbs less than required. Don't want to go thru this again while changing my brakes. I ended up buying a set of four bolts from the dealer for backup spares.
Old Aug 2, 2006 | 10:25 PM
96i30azn's Avatar
aren't you supposed to change those and the sliders when you change brake pads anyway?
Old Aug 3, 2006 | 04:11 AM
MIXXMAX's Avatar
No, there's no need to unless they are completely shot and unusable.
Old Aug 3, 2006 | 06:54 AM
nismology's Avatar
Affirmative.
Old Aug 3, 2006 | 08:00 AM
HomeLan's Avatar
could just buy a brake hardware kit from NAPA or your local auto parts store for like $10 or so.....have that bolt you are talking about, the sliding bolt that those bolts fasten to that attaches and slides on the brackets, a few other stuff (can't quite remember), and I believe they also have new metal clips that your brake pads attach/slide on
Old Aug 3, 2006 | 08:06 AM
wlaukaitis's Avatar
Just clean them up nice with a wirewheel and grease them (a bit, don't want to attract too much dirt) a bit before you put them in
wyobbagy
Jan 3, 2023 12:03 PM
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
