exhaust system loose?
Old Aug 3, 2006 | 08:24 PM
dko683's Avatar
Hey orgers,
Everytime I go over a bump of some sort, I hear some really bad clunk noises undearneath my car. It sounds like the y-pipe or b-pipe is loose and banging against something. If this is so, can I secure it easily or do I need to get a new pipe? Thanks for any help.
Old Aug 3, 2006 | 08:29 PM
Black Maxima
Look under your car. There are two problem spots. Check the hanger/bracket between the Y-Pipe and the main Cat. It could be rusted loose. And also check the cross beam piece right after the resonator on the B-Pipe. Shake the exhaust with your hand, once the exhaust is cool of course. You will hear many noises.
Old Aug 3, 2006 | 08:31 PM
Cdg2125's Avatar
Yeah I have the same problem. My hanger between y and cat is rusted and broke off. I'm also having some crazy bees in the can noise when I accelerate. My muffler is also rusting pretty badly. I'm feeling a new exhuast real soon hopefully.
Old Aug 3, 2006 | 08:35 PM
sunten1
Budget Y - Budget Cat - SP2 and Call it a day
Old Aug 3, 2006 | 09:05 PM
Cdg2125's Avatar
that was my plan. just raising the money now
Old Aug 3, 2006 | 09:15 PM
dko683's Avatar
i think my hanger has rusted. Can I just replace it?
Old Aug 3, 2006 | 09:25 PM
Black Maxima
Yes, you can replace it. But, good luck getting at the rusted bolts. The three exhaust components (Y-Pipe, Hanger, and Cat) are pretty much rusted into one piece right now.
Old Aug 4, 2006 | 03:43 AM
njmaxseltd's Avatar
Heat is your friend, and lots of it. Get an acetylene torch on those nuts and bolts and heat them till they glow red. They will twist off like butter once there red hot.
Old Aug 4, 2006 | 07:30 AM
aznsap's Avatar
ya, my friend w/ a max had that hanger @ the ypipe and cat junction rusted in half. we just pulled off the two pieces from the rubber hangers.
Old Aug 4, 2006 | 09:20 AM
Black Maxima
New exhaust FTW.
Old Aug 4, 2006 | 09:34 AM
Fang_DH's Avatar
Yea I had that happen. Just took some padding and tied it down on the bar with some thick metal wire just to keep it from banging. I'll be getting a new y-pipe here soon though.
Old Mar 19, 2007 | 08:41 AM
DanGK's Avatar
I have similar problem. Haven't got under the car yet, but how much will the budget new parts cost?
Cheers
Old Mar 19, 2007 | 10:05 AM
maxima985spd
around $550 - 600 shipped Us dollars
Old Mar 19, 2007 | 06:34 PM
Grand_hustle17's Avatar
i remember when my best friend had that problem... it could also be your exhaust, the hanger on it might be broken also
Old Mar 19, 2007 | 07:11 PM
OnEBadAsSi30's Avatar
Is they're anyway to get Polyurethane exhaust hangers? I know it'll make it feel like the car is shaking but then the exhuast would not move at all.
Old Mar 19, 2007 | 07:19 PM
Neo Raven456's Avatar
When you order a budget cat will it come with hangars for the y-pipe -> cat spot, only wondering because I bought one of those y-pipe from CE in the 4th gen classifieds that didn't come with any accessories.
Old Mar 19, 2007 | 08:03 PM
maxima985spd
Budget y-pipes dont come with hangers...you really don't even need to use one.
Old Mar 19, 2007 | 08:12 PM
But do Budget Cats? Is there even a hanger between the cat and y-pipe?
Old Mar 19, 2007 | 09:21 PM
WhiteA32's Avatar
No
10 letters
Old Mar 20, 2007 | 01:32 AM
rvaladez34's Avatar
yeah, i was pretty much having the same rust problems. the b pipe (i think) more like the shielding on it is starting to wear and expose some of the insulation around the pipe. I decided to replace the whole exhaust. as i understand it, i only need the y pipe and cat back right? i got one of the CE y pipes. Any suggestions on the cat back? anyone know if N1 is any good?
Old Mar 20, 2007 | 08:18 AM
WhiteA32's Avatar
IIRC the N1 exhaust is just a universal muffler. N1 was never a cat-back exhaust for our cars.
Old Mar 20, 2007 | 09:52 AM
Yes, an N1 is just a universal muffler. You'll also need a Catalytic Converter if your redoing the whole exhaust.
It goes: Y-pipe -> Catalytic Converter -> B-Pipe -> Muffler
If you get an N1, CE Y-Pipe, and Cat, you'll still need a B-pipe.
Cat-backs include the B-pipe + Muffler, popular ones are the GReddy SP2, Apexi WS2, Cattman, and Warpspeed Catback (Which is Magnaflow if IIRC)
Old Mar 20, 2007 | 11:12 AM
ALSOUSA99MAXIMA's Avatar
this might sound silly but..........if its only happing over bumps ans shyte it could be you shock bushings.
Old Mar 20, 2007 | 12:43 PM
Gismo-T's Avatar
B!tch We Got a Problem
Hey Al,
It does sound silly
Most likely it's just the B-pipe moving around. Same thing happened to me, till I changed the rubber hanger (stiffer one) & used a coat hanger to hold it from moving.
Old Mar 20, 2007 | 01:57 PM
rvaladez34's Avatar
I see. What about this JDM N1 system I found on ebay? anyone have any experience with it? is this and the y pipe all i would need for the exhaust?
http://cgi.ebay.com/ebaymotors/JDM-N...92260174QQrdZ1
Old Mar 20, 2007 | 09:22 PM
I would advise against it, and getting something already tested and quality. If you got the CE Y-Pipe from the classifieds your going to need 3 new gaskets from nissan, as well as a new cat, unless your reusing your old one. In that case you'll need new gaskets for that as well
Old Mar 21, 2007 | 08:37 AM
WhiteA32's Avatar
Personally I would go with the Greddy SP2, not some ebay knock off
Old Mar 21, 2007 | 10:07 AM
Originally Posted by Gismo-T
Hey Al,
It does sound silly
jerk!!!
j/p
Old Mar 21, 2007 | 11:19 AM
maximus_pr's Avatar
Originally Posted by dko683
Hey orgers,
read this
http://www.jatan.net/tsbs/041296.pdf
Old Mar 21, 2007 | 04:51 PM
rvaladez34's Avatar
I would too, but at twice the price, I would like to know exactly what the difference is from somebody that has more knowledge on the subject than me. What about Pacesetter and Megan?
Old Mar 23, 2007 | 12:21 AM
rvaladez34's Avatar
anyone know how much a SS y pipe is supposed to weigh?
Old Mar 23, 2007 | 04:04 PM
talisman311's Avatar
While we're on the topic of catback systems for maximas, has anybody had experience with the catback system offered by Warpspeed? my gasket is beginning to leak between my b-pipe and muffler, and also around my cats (warp speed y and resonated test pipe right now..). I figured I'd just replace the whole thing since there's a fair amount of rust on the catback. I was looking at the 2.5" "Q" and also the one with the magnaflow but was wondering about quality, fitment, and sound. I don't mind some deep grumble when I get on the gas but nothing irritates me more then exhaust drone. Just wanted to know if anybody had some opinions on these. Thanks all.
Old Mar 23, 2007 | 05:56 PM
just an update guys, Finlay got rid of that clanking noise. Bear with me I am a horrible typer!
My cat back was making that clanking noise, so i jacked the car up today and inspected the area. I saw that the cat back was hitting, where it goes up and over the dead axle.
This might sound hack, but it worked, and i don't think it is!
What i did was I went to autozone a rubber strap clamp, i wrapped it around the section that was hitting the dead axle and i no longer get that clanking noise.
Old Mar 23, 2007 | 07:16 PM
Gismo-T's Avatar
If you wrapped it around the pipe, the rubber strap will melt!!! =
Old Mar 24, 2007 | 01:42 PM
no it wont, its not gonna get hot enough to melt it. trust me
BkGreen97
Apr 2, 2016 05:47 AM
homeofbacon
Sep 23, 2015 07:17 PM
carid
Sep 9, 2015 05:06 AM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
