throwing 0701, help needed
Old Aug 4, 2006 | 09:55 AM
my99maxisnice's Avatar
My car has been driving rough for a while, (jerking at stop lights) and I figured it was the dreaded 99' coil pack problem. Finally last night, it started driving terribly, jerking while driving as well, and the SES light came on, and flashed a couple times twice (misfire, correct?). So I got it home safely and pulled the codes and all I got was the 0701. I read the thread in the FAQ for this code, but I'm not throwing any of those other codes. Would the problem still be the CAS? I tested all 6 coils (I'm pretty sure I tested them correctly) and they all tested fine. It says that the ohmmeter test isn't fool proof, so how can I go about figuring out which ones are bad? Any help would be greatly appreciated.
Old Aug 4, 2006 | 10:49 AM
svojs's Avatar
Multiple cylinder misfire. It's time to replace all six pack (I mean coil pack) and plugs.
By doing so, it should kill the problems. Then take some time to deal with throttle body and MAF.
The 99 coil packs suck......
Old Aug 4, 2006 | 10:54 AM
Where is the cheapest place to get new coil packs if I should replace all 6? Thanks, that's what I figured the answer was, but not what I wanted to hear.
Old Aug 4, 2006 | 01:02 PM
svojs's Avatar
http://forums.maxima.org/showthread....=autozone+coil
Good luck!!!
smplyamzng
Dec 13, 2015 01:19 PM
ef9
Aug 27, 2015 10:17 AM
TonyJr
Aug 20, 2015 12:14 AM
doobadoo
Aug 15, 2015 06:43 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
