replacing rear window glass
Old Aug 6, 2006 | 06:34 PM
dko's Avatar
dko
duck and cover
some as$hole broke my rear corner window. i've already got the replacement from a junkyard, just wanted to see if anyone had a howto with pics. someone mentioned that you have to remove the main glass and then slip in the smaller corner piece.
Old Aug 6, 2006 | 07:00 PM
Neo Raven456's Avatar
Have you checked the FSM? BF-37 is a guide to removing the glass, not sure if it helps for the rear corner window though
Old Aug 6, 2006 | 07:08 PM
dko's Avatar
dko
duck and cover
yeah, it doesn't list anything about the corner glass. just the rear windshield and rear window
Old Aug 6, 2006 | 08:38 PM
ImmaSquashYou's Avatar
take a closer look at the weather stripping, you have to take ur rear window off first. Follor the black metal bar that hold the rear corner glass in place. There will be a screw that you have to unscrew. Its only one. You can take that bar off and then remove the rear window glass. I removed it when i tinted my windows myself.
Old Aug 7, 2006 | 09:29 PM
96i30azn's Avatar
heh, how'd they take it off at the junkyard? means it cant be too hard right?
Old Aug 8, 2006 | 12:21 AM
dko's Avatar
dko
duck and cover
thanks. i'll give it a shot tommorow. nice to know there are still some helpful people in the 4th gen forum. if i see another gas mileage thread......
real helpful, buddy.
1. no one "takes it off" for you at the junkyard. you do it yourself
2. it's a junked car, so i don't care about ripping out the window trim and popping the glass out. i do care about my car, which is why i asked how to do it correctly
Old Aug 8, 2006 | 12:53 PM
Maxima_Joe's Avatar
4th Gen Parts King
You do have to remove the main glass piece. The you have to remove the metal bar seperating the two glasses. There is a small phillips screw at the top holding it in under the weather stripping. Then there is two 10mm bolts. Thats all there is to it.
Old Aug 8, 2006 | 10:27 PM
dko's Avatar
dko
duck and cover
that's what i gleaned from the previous post. thanks again.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
