Why you SHOULDNT do burnouts in your 4th gen maxima. *pics*
Old Aug 8, 2006 | 06:17 PM
NewEngSurf's Avatar
Because your cluch will look like this
Old Aug 8, 2006 | 06:18 PM
NewEngSurf's Avatar
OK ok.... whats done is done. Iv learned my lesson that i will never do burnouts again wiht on a slipping clutch. out with the old in with the new
5th gen clutch
5th gen clutch pressure plate
Fidanza aluminum flywheel
Pulled the tranny out on sunday and it came out pretty smoothly with a few extra hands. Took off intake, battery, starter, crank sensor, speed sensor, few other sensors, both axles, motor mount and lowered the engine a few inches by putting a jack under the unbolted crossmember and the tranny slid right out. I found out i could have gotten away with only taking out the drivers side axle and there is no need to completly remove the crossmember, just lower it down, and no need at all to remove they y-pipe. I just installed the new clutch, pp, and flywheel this evening and the tranny was in by 8:45, tomrrow just gota torque the bellhousing bolts and put everything else back together. I gota put in some fresh tranny fluid and hopefully i will be breaking the new clutch in tomrrow
Old Aug 8, 2006 | 06:21 PM
NewEngSurf's Avatar
family photo
vsamoylov
hows the fitment on the fidenza flywheel?
Old Aug 8, 2006 | 06:45 PM
NewEngSurf's Avatar
like a glove, not a bad price threw ultrarev.com, it was around 380 shipped
Old Aug 8, 2006 | 06:58 PM
Fre$h_TurK
sticky this
Old Aug 8, 2006 | 07:09 PM
MaximaSE96's Avatar
Maxima Owner
y should this be sticky....
Old Aug 8, 2006 | 07:34 PM
BumbleB80's Avatar
I was just wondering, how long does it take to pull out the tranny. Cause I have to swap mine out soon since I have a bad input shaft bearing. I've done struts, calipers, water pumps, alternators. How does changing the clutch compare in terms of difficulty and time?
Old Aug 8, 2006 | 07:49 PM
Apparition's Avatar
Ichiban King
I was wondering the same thing..
Old Aug 8, 2006 | 09:18 PM
ThurzNite's Avatar
hmm. use less grippy tires next time for burnouts.
Jae
Old Aug 8, 2006 | 09:28 PM
i30ds's Avatar
Armed and Dangerous
I have a manual so I can do burn outs... its only a clutch. $150 and an afternoon and you have a new one.
Old Aug 8, 2006 | 09:49 PM
chillin014's Avatar
you can change that **** on an auto?
Old Aug 8, 2006 | 10:18 PM
Apparition's Avatar
Ichiban King
Jae
Hmm..Super extreme all seasons made of plastic like a bigwheel?..
i30ds's Avatar
Armed and Dangerous
Who's auto??
Old Aug 8, 2006 | 10:25 PM
chillin014's Avatar
Originally Posted by i30ds
Who's auto??
well you said "i have a manual so i can do burn outs" so i was like wait....hes not manual?
Old Aug 8, 2006 | 10:47 PM
ThurzNite's Avatar
hey, before you toss out the old disc, can you lay it flat on a table, and stick a penny in a groove (like how you check the tread depth of a tire). You'll probably hafta use macro or portrait setting of the camera for that. I wanna see how much meat u had left on there. Thanx.
Jae
Old Aug 9, 2006 | 07:43 AM
devast8's Avatar
how's the feel between the 4th and 5th gen clutch?
Old Aug 9, 2006 | 08:34 AM
i30ds's Avatar
Armed and Dangerous
I'm not manual?? ... Could have fooled me.
Old Aug 9, 2006 | 09:23 AM
Mr Willis's Avatar
Originally Posted by Fre$h_TurK
sticky this
sticky THIS! LOL jk. Yeah why sticky this?
Old Aug 9, 2006 | 09:24 AM
chillin014's Avatar
Was referring to the op but dude...nevermind...
Old Aug 9, 2006 | 11:51 AM
NAPhi_Shift's Avatar
lol damn, yeah dont beat on your car, its def not worth it.
Old Aug 9, 2006 | 12:24 PM
mbandi's Avatar
Da'Burgh, Go Stillers!
That's not the only reason why you shouldn't do burnouts.
Old Aug 9, 2006 | 12:49 PM
smotz's Avatar
Brain phuck
clutch is like $200. New front tires is like $300. And dont forget you can blow your cv boots and have to need new axels too. Clutch is least of your worries.
Burnouts probably aren't what caused your clutch to fail, more likely bad driving in general wore it down faster then the burnouts.
Old Aug 9, 2006 | 01:17 PM
boostlogic's Avatar
4th gen
I got a stock clutch cheap on discount up at work and it made a total of 39 1/4 passes before it started slipping, and I heated the tires up real nice in 2nd gear every pass- but yours probably wasn't brand new either, haha.
Old Aug 9, 2006 | 01:22 PM
Godson's Avatar
Agreed. Just unnesecary too,always some douche in a civic doing a burnout with all his buddies holding the car back.
Old Aug 9, 2006 | 02:34 PM
willard00's Avatar
yea and cause you'll blow up your differential.
Old Aug 9, 2006 | 03:26 PM
nismology's Avatar
10frijoles
Old Aug 9, 2006 | 04:56 PM
Apparition's Avatar
Ichiban King
hey at least we dont have Evo's or STi's, my friends with them learned real quick to not do **** like that. Not much burning out but dropping the clutch at 6k is not my idea of awesome.
Old Aug 9, 2006 | 05:42 PM
MaximaBoy04's Avatar
on the G coupe bandwagon
Wow, just noticed in boost's sig that your z is putting down 829hp at the wheels...scary.
Old Aug 9, 2006 | 06:00 PM
eturnl
HMMM... how can a burn outs wear your clutch like that? Maybe i'm not understanding what a burn out is.... But if you accelerate super hard (and even if you, hypothetically, have the handbrake applied) as long as you've disengaged the clutch, whats the problem?
Old Aug 9, 2006 | 06:35 PM
96blkonblkse's Avatar
i use to do alot of burnouts in my maxima when i was 16-17. I pulled my clutch 2 weeks ago cuz my tranny diff bearing went and changed the clutch while i was at it. 290,000kms (180,000miles) and i still could have got another 30,000kms out of it. Replaced it for a 5th gen clutch and pp and im lovin it! for those who say burnouts are stupid bla bla bla....enjoy life, its to short.
Old Aug 9, 2006 | 08:49 PM
XeroX's Avatar
Hella internets
Im sure i rather enjoy spending the money u probly spend on tires...on some mods....
Burnouts < More mods
Old Aug 9, 2006 | 10:23 PM
ethnic6's Avatar
I feel like I need to change my clutch looking at this...
Old Aug 9, 2006 | 10:34 PM
craigl33's Avatar
cool;;;;;;;
Old Aug 9, 2006 | 10:36 PM
Apparition's Avatar
Ichiban King
Originally Posted by craigl33
cool;;;;;;;
^ says the moron who enters..
Old Aug 10, 2006 | 05:40 AM
willard00's Avatar
because everything is spinning really fast against resistance and it all gets reallly hot and burns. i actually have seen gears that welded themselves together.
not good for ure tranny at allll
Old Aug 10, 2006 | 05:44 AM
willard00's Avatar
for those who do burnouts, enjoy spending money you wouldnt have to spend if u just didnt act like an idiot
Old Aug 10, 2006 | 09:33 AM
HomerMAC's Avatar
Donating i30 Owner
accelerating hard is okay... (i mean it wears things but wont kill)
now its hard to accelerate wiht the handbrake applied.. and even harded to accelerate with the clutch disengaged...
Burnout:
handbreak applied (or not) + rev up high + engaging clutch = tirespin, smoke, burning rubber smell (burnout)
Old Aug 10, 2006 | 12:11 PM
Apparition's Avatar
Ichiban King
Originally Posted by HomerMAC
Burnout:
.. and you can't forget the ppl staring at you like you're a total idiot..
Old Aug 10, 2006 | 05:14 PM
swmtam's Avatar
Just a quick question for those with 5th gen clutches.
Did you guys go with the 240mm or 250mm pressure plate?
I know that the 4th gens have 240mm ones, but read that the 250mm ones were ok too. Is this true?
I'll probably be ordering the parts soon.
These are the part numbers that I have for the 5th gen clutch parts.
Are these correct? Thanks!
Release bearing: 30502-41U20
Clutch disk: 30100-2Y904
Pressure plate:
30210-89F00 (all first production date A33's until November 2000 - 240mm 635 kg clamping force)
30210-2Y920 (11/2000 to the end of A33A build - 250mm 750 kg clamping force)
I think the oem 4th gen has 580 kg clamping force.
