Speedometer stoped working
Alright well my speedometer just stopped working this week and also the cruise control. Any body have any clues as to what caused it? There are no codes as my check engine light has not come on yet, so I am guessing it is not the VSS sensor. I have had codes for other things such as knock sensor and crankshaft sensor that I have fixed so I know the light on the dash is not burned out and is functional for the codes. Car is 95 Maxima SE, w/auto.
Anybody?
Anybody?
It's probably a dead cluster - bad electrical connection somewhere inside. Replacement is another option - if you're interested in an SE cluster (white gauges) with 125k, send me a PM.
I have the spare cluster because my speedo / odo died, but I also got the VSS code. It turns out my cluster was fine, and my VSS was shattered inside the tranny
All better now though.
Dave
All better now though.Dave
My friend had the opposite happen in his 96. His speedo stopped working and he got the VSS code. So he replaced the VSS with no results... even the code remained. He finally put in the new speedo and cleared the ecu and he was back in business.
I have a similar problem...need an opinion
I have an intermediate speedometer problem, when it doesn’t work all I have to do is go over 60mph and the gage jumps up. This problem is gradually getting more frequent for the past two years. The check engine light is not on and from reading everything I can’t decide if I need to change the speed sensor or the cluster. Also, I checked and the cruise control doesn’t work when speedometer is not working. I know this not a big deal but it gets annoying after a while. Anyone has any ideas?
Similar problem... need your opinion
I have an intermediate speedometer problem, when it doesn’t work all I have to do is go over 60mph and the gauge jumps up. This problem is gradually getting more frequent for the past two years. The check engine light is not on and from reading everything I can’t decide if I need to change the speed sensor or the cluster. Also, I checked and the cruise control doesn’t work when speedometer is not working. I know this not a big deal but it gets annoying after a while. Anyone has any ideas?
Maxima30
Sep 7, 2015 06:13 PM
