Service Engine Light?
Old Aug 13, 2006 | 08:37 PM
x X CLoud X x's Avatar
need help on a quick fix..... i was cleaning out the air filter, unplugged the Sensor near it.... and put everything back together, but totally forgot about plugging back in the sensor... few hrs. later, i reversed car out of drive, and a big hestitation came (felt like someone hit the breaks), then the "Service Engine Soon" light came on.. and i shut the car off, and plugged the sensor back in, and now that light wont come off.. help...
Old Aug 13, 2006 | 08:38 PM
descent's Avatar
reset the ecu or just wait
Old Aug 13, 2006 | 08:46 PM
99se5speed's Avatar
SHIFT_up
Your next question will probably be how do i reset the ecu? Well you can find that in the stickies or you get just unplug your battery over night and that should reset it.
Old Aug 13, 2006 | 08:50 PM
Fang_DH's Avatar
Yea just look up how to reset it. It takes seconds to do.
Old Aug 13, 2006 | 09:03 PM
i unpluged the both battery terminals for a over min.... but i'll try a little bit longer tomm...
Old Aug 14, 2006 | 09:59 AM
JPMax's Avatar
What's next!?..
Get a screwdriver and just reset it.
http://vbxmaxima.8m.com/ecu.html
Old Aug 14, 2006 | 10:28 AM
svojs's Avatar
No, for 99 MAX, the screw on ECU is quite different. It makes difficult turning. The best and easiest way is using an OBD2 scanner to reset ECU.
Old Aug 14, 2006 | 11:11 AM
JPMax's Avatar
What's next!?..
He didn't specify if he has a 99.
But, my brother has a 99 and we've done it a few times.
Only difference is you need a small phillips screwdriver instead.
Not that hard. Just take it easy when turning the screw.
Old Aug 14, 2006 | 01:00 PM
svojs's Avatar
But the label on the ECU screw hole reads a little bit wierd. It reads "idle speed control" or something. I tried to pull the code by turning the screw before, but I gave it up instead of using an OBD2 scanner. Just my $.02.
Old Aug 14, 2006 | 06:20 PM
PLUMMAXSE's Avatar
Just leave it alone and it will reset itself after a few days. It just needs to check to make sure the sensor is good, then it will reset.
Old Aug 14, 2006 | 07:42 PM
thanks for all the suggestions..... and this is a 97max....
Old Aug 14, 2006 | 07:43 PM
Apparition's Avatar
Ichiban King
WARNING: be damn careful with that screw as to not overturn it, it is NOT durable in the least if you over tighten even a small amount a few times.
Old Aug 14, 2006 | 08:40 PM
Nissan 6's Avatar
In no way is Apparition responsible for your doings.
Old Aug 14, 2006 | 09:05 PM
Apparition's Avatar
Ichiban King
crap! forgot the disclaimer again.. thanks for throwing that in there.
Old Aug 14, 2006 | 09:09 PM
Nissan 6's Avatar
I had to add it in there, but also I forgot to put the disclaimer part in mine :haha:
Old Aug 22, 2006 | 01:08 PM
radarvector's Avatar
Help with CEL codes
My CEL came on and the codes were 03 04 (Knock Sensor) and 10 03 (Park/Neutral Position Switch). The only problem is I have a 99 SE with a 5 speed. I reset the codes and the same ones came back after about 300 miles. Obviously these codes are wrong as I am not having any problem with knocking and I don't have an automatic transmission. Any suggestions? I will have to have the light off to pass inspection.
Old Aug 22, 2006 | 04:03 PM
JwaxMax99's Avatar
5 Speeds have a Park/Neutral position switch too. It's also a back up lamp switch.
And, a bad KS does not cause knocking.
Old Aug 30, 2006 | 12:11 PM
fran
thank for all your help.
Old Aug 30, 2006 | 12:44 PM
Nissan 6's Avatar
WHAT THE GAY!! Stop bumping threads with your worthless response
Old Aug 30, 2006 | 12:50 PM
aih98max's Avatar
scoobystoned...
what the *** is wrong with you you worthless piece of shizzle
Old Aug 30, 2006 | 01:08 PM
Frank Fontaine's Avatar
But if the battery gets unplugged, then the presets for the stereo gets messed up, as does the temp if equipped with auto climate control.
Old Aug 30, 2006 | 01:43 PM
aih98max's Avatar
scoobystoned...
just do it with the screw, way easier
Old Aug 30, 2006 | 05:44 PM
Apparition's Avatar
Ichiban King
thank god you're banned.. you give maxima owners a title beyond just
Old Aug 31, 2006 | 05:03 AM
Allens96SE's Avatar
My CEL comes on and off intermittenly and the only code it throws is 5-5 which means nothing is wrong. BUT I can free-spin the screw on my ECU (previous owners fault) it never really "stops." Does anyone know if my ECU is beyond repair?
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
