Pealing-out
Old Aug 15, 2006 | 01:58 PM
RKZ's Avatar
RKZ
Pealing-out
I've noticed driving my car i can't peal out if i floor the accelerator anyone else have this problem? should i have my car looked at or something?
Old Aug 15, 2006 | 02:03 PM
EnervinE's Avatar
i has college
Could be a variety of problems. If you've got a CEL check the codes and see if you get a knock sensor fault. If so, that's your problem, your knock sensor's gone bad, and your ECU is bottlenecking the power of your engine.
Otherwise, maybe you're using a lower octane gas or maybe you got new tires. No one can really tell unless you give us more info.
Old Aug 15, 2006 | 02:05 PM
descent's Avatar
I thought the more worn a tire the less it grips, hence you can peel out even more?
Old Aug 15, 2006 | 02:06 PM
EnervinE's Avatar
i has college
Doh. fixed.
Old Aug 15, 2006 | 02:32 PM
NmexMAX's Avatar
dot dot dot ...
Get a dyno to see if your car is really lacking power.
Anyone can 'peel out' with the right tires.
Old Aug 15, 2006 | 02:34 PM
dgeesaman's Avatar
Maintenance Monster
You can peal out with the right bells. Or any bell for that matter.
We have a bell housing, but no bell?
Old Aug 15, 2006 | 02:41 PM
Dubbya's Avatar
VK56 Inside
Are we talking oranges here?
Old Aug 15, 2006 | 03:24 PM
udienow's Avatar
I cant answear your question but I can say that I have the same problem.
I have used 93 since i got the car over a year ago, I have 2.5inch header-back exhaust with no cat, intake, no codes but the rear o2 code, and still have a hard time peeling out.
Old Aug 15, 2006 | 03:32 PM
dgeesaman's Avatar
Maintenance Monster
http://dictionary.reference.com/browse/peal
Old Aug 15, 2006 | 03:37 PM
valvestud's Avatar
who cares? u have an AT?
Old Aug 15, 2006 | 04:04 PM
RKZ's Avatar
RKZ
Theres no CEL should i go check for codes anyway? and should i replace knock sensor, MAF and the o2 just to be on the safe side?
Old Aug 15, 2006 | 04:12 PM
dgeesaman's Avatar
Maintenance Monster
O2 does not affect power under heavy load. Leave it alone unless you're getting an o2 sensor code, in which case fixing it will probably still not improve power.
Definitely check for ecu codes - there are some codes like the knock sensor that don't set the light.
Knock sensor may have some effect, if you check for codes and find a knock sensor code, all by itself, I would replace it. But not until it's the only code and it keeps coming up when running premium fuel.
Lower octane gas will not change power output unless the ecu has detected knock and adjusting the timing. That's the purpose of the knock sensor - in which case you should switch back to higher octane fuel and reset the ecu. If you don't get any ecu codes, it's not happening.
Grippy tires will give you more traction. You will be able to launch faster because it's harder to get wheelspin. As well, in summer the temps make the tire softer and more grippy then in colder temperatures. So in winter it's fairly easy to do no matter what tire you have.
Dave
Old Aug 15, 2006 | 06:16 PM
DaGGer's Avatar
If you have an A/T then most cars can't burn out by just stomping the gas. It doesn't have the sudden shock that lets the tires loss grip.
Old Aug 15, 2006 | 06:39 PM
chillin014's Avatar
check your tire PSI. fill her up to 32.
Old Aug 15, 2006 | 06:49 PM
Black Maxima
Automatic 4-speed + FOR THE LOSE = NO peEling out.
Old Aug 15, 2006 | 06:51 PM
chillin014's Avatar
dude i literally PEALED the f*ck out going up a driveway in the rain okay, so dont you dare tell me my AT isnt putting the power to the ground. i hardly have traction in the rain.
Old Aug 15, 2006 | 07:42 PM
DaGGer's Avatar
if its raining almost anything can burn out. My ranger can burn out through 3rd gear, thats like 75 mph when it rains. Autos just don't have the same ability to burn out on dry pavement as a manual vehicales do.
Old Aug 15, 2006 | 07:43 PM
chillin014's Avatar
lots of good info in this thread. thanks.
Old Aug 15, 2006 | 08:16 PM
Black Maxima
10/10 would read again.
Old Aug 15, 2006 | 09:44 PM
96i30azn's Avatar
I can't peel out either, dont feel bad. All you have to do is turn your wheel or brake rev, anything than just nailing the gas.
Old Aug 15, 2006 | 09:46 PM
D-Bo's Avatar
Droppin logs
Total thread failure.
/thread
Old Aug 15, 2006 | 09:51 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Another great use of .Org bandwidth
Old Aug 15, 2006 | 10:27 PM
Apparition's Avatar
Ichiban King
But you have to ask yourself, is there a spoon?
hey btw, found your myspace.. and you have an add.
Old Aug 15, 2006 | 10:54 PM
MAXorBUST's Avatar
i have a 5 spd i must say its failry easy to "peel out" lol
MANUAL FTW!!!
Old Aug 16, 2006 | 04:23 AM
nguyen925's Avatar
AT are not made to peel out, that being said i wish my car was a manual for many reasons..
Old Aug 16, 2006 | 05:34 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
theres no reason to try and peel out with an a/t. That said when i left the house mad the other day (i know, i was being an ***) i punched it and my auto spun first and second, and chirped when it hit third. So they CAN, but why bother trying?
Old Aug 16, 2006 | 06:10 AM
97BlackSEGold's Avatar
so you were spinning your tires in an auto until you hit about 65mph????
Old Aug 16, 2006 | 06:22 AM
scubasteve's Avatar
if thats the speed i wasnt paying too much attention to the guages i was on the phone with my now ex having a wonderful (read ) conversation. my drive way goes down and too the right, if that makes a diff?
Old Aug 16, 2006 | 06:26 AM
NmexMAX's Avatar
dot dot dot ...
Peeling out is
Old Aug 16, 2006 | 07:32 AM
Black Maxima
error 404: Peal-out not found.
Old Aug 16, 2006 | 09:04 AM
im not sure, i dont ever burn out in my car, in some cars the speedo goes way up with the wheel speed when theres no traction but idk if our cars detect the speed like that. I do know that my friend spun his speedo almost all the way around when he just stomped on it in the snow and it never went back. funny ****, but no you wouldnt actually be goin that fast, i meant 3rd gear not 65, im trying to work and check out the org at the same time. i was just thinking about what wot shift points are
Old Aug 16, 2006 | 09:05 AM
scubasteve's Avatar
that was pretty good lol
Old Aug 16, 2006 | 09:08 AM
Donald199's Avatar
once i had a set of REALLY REALLY worn out tires, the tires would keep on spinning if i floor it at like 30mph where the tranny kick-down LOL
Old Aug 16, 2006 | 09:58 AM
queenambeach's Avatar
Why exactly do you need to peel out again??
Old Aug 16, 2006 | 10:12 AM
EnervinE's Avatar
i has college
Why exactly are you trying to continue this failure of a thread again?
Old Aug 16, 2006 | 11:16 AM
dude this thread is useful.......
Old Aug 16, 2006 | 11:18 AM
Apparition's Avatar
Ichiban King
If you want mad pealing-out with FWD Action!!!! Then buy a Big-Wheel.
Old Aug 16, 2006 | 11:27 AM
haha how else can you burn out with like 5 horsepower
Old Aug 16, 2006 | 12:03 PM
scubasteve's Avatar
my big wheel > your big wheel
Old Aug 16, 2006 | 12:07 PM
ALSOUSA99MAXIMA's Avatar
This is why i dont come in here any more
